Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Audi ei käivitu
Pealkiri: Audi ei käivitu (Vastuseid: 8 | Vaatamisi: 1217)
Timmu-Vimmu
Registreerunud 19.02.08
postitati 21.03.08 16:26 Tsiteeri
Audi ei käivitu
Mure siis järgmine, et ükspäev sõitsin oli kõik ok, järgmine hommik autosse istudes enam käima ei läinud, pikemalt starterit andes kõlas armatuuris kolm piiksu, oskab keegi kommenteerida sellist seikka? Autoks siis A6 95a.
pampkuri
Registreerunud 08.03.04
postitati 21.03.08 16:30 Tsiteeri
Kuule loe algatuseks foorumi reeglid läbi ja siis tee teema korda vastavalt reeglitele.
a6quattro
Registreerunud 27.12.07
Auto: AUDI A8 Quattro TDI
postitati 22.03.08 07:44 Tsiteeri
huvitav oleks teada mis tüüpi mootoriga ka tegemist:o
Timmu-Vimmu
postitati 22.03.08 11:47 Tsiteeri
motoriks on 2,6 bensukas
Cari
Registreerunud 22.08.07
Auto: Audi A6
postitati 22.03.08 13:49 Tsiteeri
kontrolli bensupumpa
Timmu-Vimmu
postitati 24.03.08 15:09 Tsiteeri
Sai siis täna uuritud seda kütusepumpa, sellega on ok, kõik toimib. Seega, otsustasin ta käima lükata ja ennäe imet läkski, jätsin seisma ja proovisin võtmest, toimib. lased natuke seista ja võtmest jälle ei lähe. Siin saigi minu arusaamine sellest ots, kas kellelgi on veel nii juhtunud?
jokker
Registreerunud 10.07.05
Auto: A6 '96 ABK
postitati 24.03.08 15:24 Tsiteeri
Peale käiamist keera korra mõni küünal maha, äkki tõmbab täis? Kas jama on nii sooja kui külma mootoriga? Need 3 piiksu on arvatavasti õlirõhu piiksud.
joyrider
argos
Registreerunud 31.08.07
Auto: Audi A6 Avant 2.5TDI 96'
postitati 24.03.08 15:26 Tsiteeri
Ma pole ausalt öeldes kohe absoluutselt 2.6 eluoluga kursis, aga ehk on neil kõigil see värk sarnane.
Kontrolli ära kütusesüsteemi jääksurve. See peab jääma mingile kindlale tasemele pärast seismist, mitte nullu vajuma.
Seda saad mõõta näiteks külmkäivituse pihusti alt(juhul, kui sul selline asi seal eksisteerib)
Vabandust, kui mööda panin :/
"never crash on understeer, it makes you look like an amateur.."
Timmu-Vimmu
postitati 24.03.08 15:32 Tsiteeri
Praegu just proovisin käima panna ja ennäe, läksi "võtmest"
[PHP: 33.2% - SQL: 66.8%]
