Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - 92 b4 puterdab tühikäigul ja käivitub halvasti .
Pealkiri: 92 b4 puterdab tühikäigul ja käivitub halvasti . (Vastuseid: 15 | Vaatamisi: 1506)
mkahro
Registreerunud 20.03.08
postitati 20.03.08 14:58 Tsiteeri
Mul siuke jama et tühikäigul auto paugub õrnalt,käivitub halvasti ja vahel tõmbab ka täis.süüde on õige! lamda ka kontrollitud.ei ole kõigeparemas korras aga töötab!:D kõrgel käigul vahel ka puterdab,ma arvan et nendes pihustites võib asi olla, aga kes teeks tallinnas seda tööd ? normaalsete hindadega ja kes ka jagaks seda asja et ma ei peaks miljon asja ära vahetama :) annaksite infot või kellegi telefoni nr-i :D oleks väga vaja .tänades teid ette :D
kahro
QUATTRO
Auto: 5,2 Cherokee 4x4
postitati 20.03.08 20:30 Tsiteeri
Truumu diagnostika.Pärnu mnt 137.
Boschi kauplusega samas majas.
mkahro
postitati 21.03.08 09:48 Tsiteeri
palju maksab diagnostika ja teevad kohapeal korda ka jah ?
kahro
jõuvanker
Registreerunud 21.03.03
postitati 21.03.08 09:54 Tsiteeri
Algselt postitas: mkahro
Loe:
Truumu diagnostika!
Leiutaja
Registreerunud 20.12.05
Auto: Audi 80 2,0 85kw
postitati 21.03.08 10:17 Tsiteeri
ma käisin just diagnostikas sama murega. põhiline vaata kõik kontaktid üle sul vb õhulugeja kontaktid ei anna hästi ühendust liivapaberiga õrnalt üle ja siis lase wd-40 õlikiht peale ja siis tee nii andurite kontaktid kah ja kõik pistikud mida leiad vaata kas läheb paremaks.;)
mkahro
postitati 22.03.08 09:25 Tsiteeri
Ja kas sa said siis korda w ? aga sul printsung w ? või mis ? :) mul see mono värk :D
kahro
mkahro
postitati 22.03.08 09:28 Tsiteeri
ja kas see õhulugeija on see mis nagu läheb salongi poolt õhupuhasti alla ? :)siuke 1,5- 2 cm lai pistik ?
kahro
-ivar-
Registreerunud 06.08.06
Auto: typ 85q & XC
postitati 22.03.08 09:52 Tsiteeri
Kontrolli jagaja seest rootor üle. Isa b4'l oli see nn ära põlenud siis oli sama jama, et auto ei käivitunud hästi ja paukus jubedalt.
Leiutaja
postitati 22.03.08 10:10 Tsiteeri
mul aitas. õhufiltri peal jah see lai pistik see puhasta ära. mul täispritsung jah aga egas seal vahet pole kui ta õhku ei oska lugeda siis hakkab jamama. muidugi ma ennem vahetasin niisama jagajakaane, rootori ja küünlad ära. võid need kah ära vahetada kahjuks ei tule ja palju ei maksa. juhtmed need juba maksavad aga võid need kah vahetada
mkahro
postitati 22.03.08 10:18 Tsiteeri
küünlad vahetatud ja juhtmed ka ,aga ma siis puhastaks selle pistiku ära ja vaatan mis saab :) aga liivapaber mahub sinna w ? :D või kruvikaga õrnalt kraapida ? :D
kahro
Leiutaja
postitati 22.03.08 11:50 Tsiteeri
nu kraabi kruvikaga või siis kruvikaotsaga hoia liivapaberit ja õrnalt puhasta peaasi et oksiidikiht maha tuleks
mkahro
postitati 22.03.08 12:29 Tsiteeri
kas sul oli ka et tuurid tõusid ja langesid ?näit et hoian ühtlaselt 2000 peal siis kukkub 1800 sekundiga ja siis tõuseb sekundiga jälle 2000 peale..jne ... siis se ma käisin enne proovimas puhastada aga see päris peen töö:)ja väga palju ruumi on :D
kahro
mkahro
postitati 22.03.08 12:33 Tsiteeri
ja käivitamine käib mul nii et pean enne starterit kaasi peal hoidma :D on tuttav teema ? :D hakkan juba tüütuks muutuma :D vabandan ,mure
kahro
Leiutaja
postitati 22.03.08 12:35 Tsiteeri
nu mul tuurid kõikusid jah. muidugi ei anna pead et ainult õhukulu pistik ainult sitane mul puhastati mootori juures kõik pistikud ja asi läks ikka väga paremaks. mul oli probleeme ülevaatusel sest kui taheti mootoril ühtlasi tuure hoida siis ei saanud ja mootor värises peal. kütusekulu oli kah suurem. et ruumi juurde saada siis võta see kaan pealt ära üldse ja hulga lõbusam puhastada. 2 vaakumvoolikut lahti ja suur lõdvik. ei ole hullu midagi.
mkahro
postitati 22.03.08 12:44 Tsiteeri
noh peab ära proovima,aja maha võtma :) tänud mees :)
kahro
Leiutaja
postitati 22.03.08 12:46 Tsiteeri
pole tänu väärt :D diagnostis raiskaksid vb niisama raha mis oleks kah jama nagu mina seda tegin kuigi kallis polnud aga seda sama oleks võinud ise kah teha:cool:
[PHP: 34.1% - SQL: 65.9%]
