Pealkiri: Kliima lisavõimalused (Vastuseid: 3 | Vaatamisi: 2783)
Geo
Registreerunud 20.09.05
Auto: 4xQ
postitati 22.02.08 06:46 Tsiteeri
Loon siia teema, mis juba eksisteerib, aga elektroonika foorumis.
Tsiteerin:
Kliima kaudu saab järgmist infot:
Changing Degree Temperature Display
Press and hold the recirculation button. Then press the temperature up ("+") button to switch between degrees Celsius & Fahrenheit on the Climate Control Temperature and Instrument Panel Outside Temperature displays.
Accessing On-Board Diagnostic codes
Press and hold the recirculation button. Then press the manual flow control up arrow. You should see a 1c. Press the temperature up ("+") or down ("-") buttons to select a code number. Then press the recirculation button again. The value should display. Press the temperature up or down button again to display another code.
NOTE: Air Flow Motor (V 71) and Potentiometer (G 113) are not installed in USA/Canada vehicles. Disregard values displayed for these components.
Code
Displayed Value
1
System malfunction - displayed as a Diagnostic Trouble Code (DTC), see chart below
2
Digital value of Interior Temperature Sensor, in Headliner (G 86)
3
Digital value of Interior Temperature Sensor, in Instrument Panel (G 56)
4
Digital value of Fresh Air Intake Duct Temperature Sensor (G 89)
5
Digital value of Outside Air (Ambient) Temperature Sensor (G 17), front
6
7
Digital value of Ambient Temperature Sensor At Fresh Air Blower (G 109)
8
Digital value of Temperature Regulator Flap Motor Potentiometer (G 92)
9
Delta value of Temperature Regulator Flap
10
Non-corrected specified value of Temperature Regulator Flap
11
Digital value of Central Flap Motor Potentiometer (G 112)
12
Specified value of Central Flap
13
Digital value of Footwell/Defroster Flap Motor Potentiometer (G 114)
14
Specified value of Footwell/Defroster Flap
15
Digital value of Air Flow Flap Motor Potentiometer (G 113)
16
Specified value of Air Flow Flap
17
Vehicle Speed (km/h)
18
Actual Air Blower voltage (Volts)
19
Specified Fresh Air Blower voltage (Volts)
20
A/C Compressor (A/C Clutch) voltage (Volts)
21
Number of low voltage occurrences, non-transient
22
Cycle condition of A/C Refrigerant High Pressure Switch (F 118)
23
Cyclings of the A/C Refrigerant High Pressure Switch (F 118)
24
Cyclings of the switches, absolute non-fluctuating
25
Analog/Digital value, Kick-Down Switch
26
Analog/Digital value, Engine Coolant Temperature (ECT) Warning Light
27
Coding value
28
Engine Speed (RPM)
29
A/C Compressor speed in rpm (Equals Engine Speed x 1.28)
30
Software version
31
Display check (all segments of A/C Control Head display light up)
32
Potentiometer malfunction counter, Temperature Regulator Flap
33
Potentiometer malfunction counter, Central Flap
34
Potentiometer malfunction counter, Footwell/Defroster Flap
35
Potentiometer malfunction counter, Air Flow Map
36
Feedback value, cold end-stop, Temperature Regulator Flap Motor Potentiometer (G 92)
37
Feedback value, hot end-stop, Temperature Regulator Flap Motor Potentiometer (G 92), max. stop
38
Feedback value, cold end-stop, Central Flap Motor Potentiometer (G 112)
39
Feedback value, hot end-stop, Central Flap Motor Potentiometer (G 112)
40
Feedback value, cold end-stop, Footwell/Defroster Flap Motor Potentiometer (G114)
41
Feedback value, hot end-stop, Footwell/Defroster Flap Motor Potentiometer (G114)
42
Feedback value, cold end-stop, Air Flow Map Motor Potentiometer (G 113)
43
Feedback value, hot end-stop, Air Flow Map Motor Potentiometer (G 113)
44
Vehicle operation cycle counter
45
Calculated interior temperature (internal software, in digits)
46
Outside (ambient) temperature, filtered, for regulation (internal software)
47
Outside (ambient) temperature, unfiltered, (internal software, in deg C)
48
Outside (ambient) temperature, unfiltered, (in digits)
49
Malfunction counter for speedometer (vehicle speed) signal
50
Standing time (in minutes)
51
Engine Coolant Temperature (ECT) in deg C
52
Graphics channel 1 - A/C compressor switch-off conditions are identified by illuminated segments of the ?88.8? display. See chart below.
53
Graphics channel 2 - Climate system electrical outputs are identified by illuminated segments of the ?88.8? display. See chart below.
54
Control characteristics
55
Outside (ambient) temperature, in deg C or deg F depending on setting on A/C control head
56
Temperature in deg C, from Interior Temperature Sensor, in Headliner (G 86)
57
Temperature in deg C, from Interior Temperature Sensor, in Instrument Panel (G 56)
58
Temperature in deg C, from Fresh Air Intake Duct Temperature Sensor (G 89)
59
Temperature in deg C, from Outside Air (Ambient) Temperature Sensor (G 17), front
60
Temperature in deg C, from Ambient Temperature Sensor At Fresh Air Blower (G 109)
61
Software version (latest)
Geo
Auto: 4xQ
postitati 22.02.08 06:48 Tsiteeri
Veelgi parem oleks kui siia teemasse keegi lisaks veakoodide tähendamist. Eks kellelegile abiks see teema.
Janis
Registreerunud 10.08.04
Auto: Subaru
postitati 22.02.08 16:20 Tsiteeri
see link siin varem ka olnud
Teemo
Registreerunud 15.10.05
Auto: Audi Quattro
postitati 22.02.08 19:16 Tsiteeri
Algselt postitas: Janis
Link on olnud jah, aga nüüd on hea, et see siin teemas on. Ei pea vajadusel meenutama hakkama, kust see link leida.;)
[PHP: 14.6% - SQL: 85.4%]
