Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Parem peegel väiksem, miks?
Pealkiri: Parem peegel väiksem, miks? (Vastuseid: 37 | Vaatamisi: 8965)
saara
Registreerunud 21.01.08
postitati 21.01.08 15:20 Tsiteeri
kas keegi teeb lõpuks blondiinile selgeks, miks on parempoolne peegel hulga väiksem kui vasakpoolne?
OnuJack
Registreerunud 10.12.07
postitati 21.01.08 15:49 Tsiteeri
mille peeglitest jutt käib?
shakel
Registreerunud 24.11.05
Auto: A8 4.2 2003
postitati 21.01.08 16:06 Tsiteeri
Eks ikka Audide küljes olevatest tahavaatepeeglitest. Need on tõesti paljude teiste autodega võrreldes väiksemad ja parempoolne vasakpoolsest veel omakorda väiksem. Miks see nii on, huvitab ennastki.
cornoyo
Registreerunud 09.02.07
Auto: s4 b6
postitati 21.01.08 17:19 Tsiteeri
:D Vanematel autodel ei olnud paremat küljepeeglit üldse olemas.
.:Rasta I Land:.
vreps
Registreerunud 04.10.07
Auto: Audi 100 2,5tdi nüüdseks ajalugu
postitati 21.01.08 17:31 Tsiteeri
Ma ei usu,et keegi teab miks see saksa insener need peeglid just sellised välja mõtles ja on sellel mingit tähtsust. Mõne aasta pärast leiti, et teeme nüüd ühesuurused ja tehtigi.
puna
Registreerunud 20.09.06
Auto: C5, Quattro, 4,2L
postitati 21.01.08 17:51 Tsiteeri
Vanematel mudelitel oli jah väiksem uutel läks juba norm suurusesse.
Taavi
Registreerunud 21.11.04
Auto: UrS4
postitati 21.01.08 17:58 Tsiteeri
C4-l nt on mõlemaid olemas. Nii pisikesed kui suured.
12.301@181km/h
vreps
postitati 21.01.08 18:04 Tsiteeri
C5 olid ka alguses väiksed kõrvalistujal.
postitati 21.01.08 18:33 Tsiteeri
enda a4-l on samuti parempoolne tahavaate peegel pisem.samas tekib ka küsimus(mis ei kuulu küll üldse asjasse),kas keegi on pannud tähele,kui palju seda parempoolset peeglit üldse kasutatakse?:D
samas ka veel,et miks peeglid näitavad erinevalt?autol siis 3 peeglit ja köik näitavad erinevalt-pean silmas kauguseid.
Tegelane5
Registreerunud 26.09.05
postitati 21.01.08 18:39 Tsiteeri
Saarlane mis moodi sa vaatad kui kaugel äärekivist oled, kui ntks nö külgboksi pargid?
Aga jah tuleb tunnistada et pesu 307 on küll paremad peeglid:(
postitati 21.01.08 19:01 Tsiteeri
Algselt postitas: Tegelane5
isiklikult on minul köik 3 peeglit alati kasutusel,kuid kui minna kuhugi parklasse vöi mujalegi tänavasse pargitud autosi vaatama siis jääb küll mulje,et parempoolset ei kasutata ja samas ka liikluses.ja nii palju on mul ka viitsimist,et minna autost välja ja vaadata kui kaugele on auto äärekivist jäänud ning nagu mainisin-peeglid näitavad eri kauguseid-seega olen ettevaatlik.9 korda külva 1kord löika.
lähenesin asjale lihtsalt enda seisukohalt:D muidugi tahaks,et enda auto peeglid näitaksid vördseid kauguseid:mad:
Kasutaja on foorumis
postitati 21.01.08 19:03 Tsiteeri
Algselt postitas: saara
Sellepärast,et blondiin on vasakpoolsele lähemal,sealt hea ennast vaadata:D
OnuJack
postitati 25.01.08 18:21 Tsiteeri
Algselt postitas: olensaarlane
Elan Taanis ja siin ilma parempoolse tahavaate peeglita oleks suht jama - kael jääks väga kiiresti kangeks, sest siin on igal pool jalgratta teed ja neile tuleb igal mahakeeramisel teed anda...
Mis peeglite erinevasse suurusesse puutub, siis on üks teooria: kas on tõsi, et väiksemal peeglil on üldiselt väiksem tuuletakistus? Kui jah, siis oleks suht loogiline, et peeglid tehakse võimalikult väiksed kuid samas piisavalt suured, et ohutust ei vähenda. Kui tuuletakistus väiksem, siis ka mürafaktor väiksem :P
Tuli selline uitmõte :)
nic
postitusõiguseta huviline
Registreerunud 01.05.05
Auto: mõned audid alles
postitati 25.01.08 18:36 Tsiteeri
IIRC, it's not that the passenger mirror is smaller, but that the drivers side mirror was made longer to include the small convex area to reduce the drivers side blind spot.
copy-paste siit:
http://www.audi-sport.net/vb/showthread.php?t=675
GT1
Registreerunud 30.07.05
Auto: Audi A4 Avant Tdi Q
postitati 25.01.08 19:53 Tsiteeri
Kunagi sai ka seda teemat uuritud, Audi insenerid mõtlesid sellega sutsu kütust säästa.....
mmkoha
Registreerunud 08.01.10
Auto: A3 Sportback 3,2 quattro
postitati 05.04.10 04:37 Tsiteeri
Tõstan üles vana teema. Kas originaalis väikese parempoolse peegliga ette nähtud mudelitel on võimalik see nn normaalsuuruse vastu varuosana välja vahetada?
jaakk
Registreerunud 23.07.07
Auto: Bmw 525i -2007, sedaan
postitati 05.04.10 05:51 Tsiteeri
Jah, kui A4-jale otsid, siis meie maale veetakse palju UK-st autosid varuosadeks ja UK versioonilt saad normaalsuurusega parempoolse peegli- http://www.velammutus.ee/
Algselt postitas: mmkoha
mmkoha
postitati 05.04.10 05:59 Tsiteeri
Hea uudis. Uurin.
postitati 05.04.10 10:40 Tsiteeri
Hea uudis. Uurin.
Halb uudis on see, et UK autode parema peegli korpuse nurk on teine, peegliklaas tuleb nihutada nii sisse kui võimalik ning nähtavus on ikka väga kehv.
Visuaalselt pole ka just kõige ilusam.
TarvoL
Registreerunud 27.09.03
Auto: Audi
postitati 05.04.10 15:13 Tsiteeri
Mul on parem peegel UK omaga asendatud ja kui regullid peegli nii et see ala mis salongipeelgis lõpeb algab küljepeelgist siis jääb see peegel sinna normaalselt ja ka nn. pimenurk on väiksem.
Kui aga panna peelgid nii nagu autokoolis õpetati et näeksid oma tagumist ukselinki siis jah peab selle peegliklaasi täitsa põhja kruttima ja see eriti ilus ei jää.
Hea uudis. Uurin.
rix30
Registreerunud 19.04.09
Auto: Audi S3 1,8T 8L
postitati 05.04.10 18:14 Tsiteeri
Imelik autot vaadata ,üks peegel väiksem.Eks inseneerid tegid veits katseid ja proovisid kuda toimib. Inimesed harjunud et vaatad auto poole siis asi parlanksis kui peeglid ühesuurused,aga miks siis paljudel autodel summuti ühelt poolt välja tuleb ja selle kohta ei küsi keegi miks see nii on? Kummaline:o:o:D:D:D:D
Imres
Registreerunud 11.03.07
postitati 05.04.10 18:46 Tsiteeri
Aga rs4 kasutab ka pikka peeglit.
Mul omal ka UK peegel ja sama probleemi pärast pole külge jõudnud veel.
Kas saaks veast lahti kui paneks rs4 peegli klaasi. Peaks olema kumer peegel ja näitama paremini!?
postitati 06.04.10 10:22 Tsiteeri
Algselt postitas: Imres
Kumerad on need peeglid kõik, juhi peeglil on välimine nurk peale kriipsu veel suurema kumerusega, et näitaks laiemalt. Seega see RS4 peegliklaas Sind ei aita. Aga pane terve RS4 peegel :P.
erki.t
Registreerunud 06.07.06
Auto: Got burger? (Jeep)
postitati 06.04.10 10:42 Tsiteeri
Tegelikult on kõik kaalus kinni - auto vajuks lihtsalt paremale imevähe lääpa, kui peeglid ühesuurused oleks - iga gramm on arvel - saksa peen inseneritöö siiski.
:P
Vihane-Tihane
Registreerunud 02.05.06
Auto: Audi 200 TQ 20v avant ja 120 Prado
postitati 06.04.10 11:18 Tsiteeri
Algselt postitas: erki.t
:P
Vaatan, et saa ei ole üldse asjaga kursis. Auto vasakpoolne külg on üldjuhul alati raskem parempoolsest (olenevalt sohvri kaalust), mistõttu too külg ka kergelt madalamal ning seetõttu kisub auto ka kergelt paremale. Kuna vasakpoolse peegli tuuletakistus suurem, siis see suunab omakorda autot jällegi vasakule. Tänu peeglite erivatele suurustele saabki üleüldse ka käed lahti sõita:P:D:D
BLOW-JOB is better then NO JOB
[PHP: 24.1% - SQL: 75.9%]
