Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Ventilaator töötab lakkamatult
Pealkiri: Ventilaator töötab lakkamatult (Vastuseid: 9 | Vaatamisi: 2421)
Shelby-SV
Registreerunud 06.01.06
Auto: Audi 80 b4 66kw 1994
postitati 19.01.08 15:46 Tsiteeri
Tere,
Mure siis selles, et jahutusventilaator töötab lakkamatult alates süüte sisse keeramisest.
Asi hakkas paar kuud tagasi lambist.
kaitsmekarbi kaane pealt lugesin välja, et relee on seal samas karbis. 2x2x2cm hallist plastist kuubik, suurelt number 214 peal.
Ostsin uue relee kuid see ei muutnud midagi.
Kui vana relee välja võtta ja sinna midagi asemele ei pane siis jääb vent vakka.
Äkki mingi temperatuuri andur hoopis saba andnud?
Ise suht võõras sel teemal.
Auto on Audi 80, 1994a, 2.0L, 66kw
Mybestfriendmyself
Registreerunud 29.09.06
Auto: Audi 100 C4 2.8 Q
postitati 19.01.08 15:59 Tsiteeri
Arvata võib et kas on kusagil termolüliti juures midagi lühisesse läinud või on termolüliti ise peetis.
Võtad oma naise ka kaasa?Tuim oled peast või?Kes siis metsa puid kaasa võtab.
Toomas15
Registreerunud 22.05.06
Auto: Audi A6 Avant C5
postitati 19.01.08 16:01 Tsiteeri
kogu aeg
Minul oli lühises termoandur radiaatoris,nii kui süüdet keerasin nii kukkus uhama,peale termoanduri vahetust asi hakkas pöörlema 95 nagu peab.
Andy
Registreerunud 17.08.04
Auto: B4, B5
postitati 19.01.08 16:06 Tsiteeri
Algselt postitas: Shelby-SV
Tere,
Võta radika küljest otsad lahti ja veendud et andur läbi, st enam ei uha ringi.
Shelby-SV
postitati 19.01.08 20:43 Tsiteeri
see andur on radika all paremas nurgas?
annab seda vahetada ilma, et kogu jahutussüsteemi tühjaks peaks laskma?
palju see umbes maksab?
wookie
Registreerunud 21.02.07
postitati 20.01.08 00:09 Tsiteeri
See andur võiks maksta umbes 200 krooni ringis.
Terve süsteem kindlasti tühjaks ei jookse. Sa võtad selle ürituse ju ette alles siis, kui vesi on maha jahtunud ja termostaat on kinni.
Teoorias peaks radiaator ja vist ka paisupaak tühjaks jooksma. See teeb antud mootori korral kokku vast mingid neli liitrit jahutsuvedelikku.
Arvestades, et see igas toidupoes 1l purkides müüdav valmis segatud jahutusvedelik on päris hea ja naeruväärselt odav, ei tee värskema vedeliku süsteemi panek ju teps mitte paha...
Kuna väike ring jääb suletuks ja sa valad süsteemi uuesti ülemise märgini täis, siis on võimalus õhumillide tekkeks väga väike. Ajad mootori soojaks, et termostaat avaneks, sõidad paar korda mõnest järsemast mäest üles ja ongi õhk läinud, üksiti saad siis kontrollida, kas ventikas rakendub õigel ajal :-)
ve1ks
Registreerunud 23.02.04
Auto: B4 Avant 2,6 V6
postitati 20.01.08 06:55 Tsiteeri
Keerad anduri lahti ja võtad uue käe ulatusse, keerad vana välja ja kohe uue asemele - jahutusvedeliku kulu pool liitrit.
OnuJack
Registreerunud 10.12.07
postitati 20.01.08 12:43 Tsiteeri
sama töö vist ees...
tegu on minu puhul 2,8 C4-ga kas sellel asub see andur samas kohas?
Masinal on küll kliima peal, kuid tundub et asi siiski kahtlane - külma mootoriga kukub kohe uhama. isegi siis kui väljas on alla +5 kraadi C ja kliima nö välja lülitatud...
ve1ks
postitati 20.01.08 14:09 Tsiteeri
Algselt postitas: OnuJack
Andur asub samuti radika alaosas, ei mäleta kummal pool oli.
OnuJack
postitati 20.01.08 15:04 Tsiteeri
Algselt postitas: ve1ks
selge :)
[PHP: 45.4% - SQL: 54.6%]
