Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - 2,5 tdi temp
Pealkiri: 2,5 tdi temp (Vastuseid: 3 | Vaatamisi: 1587)
kosmoseklutt
Registreerunud 29.09.06
Auto: A4
postitati 12.01.08 14:02 Tsiteeri
2,5 tdi temp
njaa
mul pole temp näidik kunagi üle 70 näidanud..
tavaliselt u 65 kraadi..
talvel käivitub hetkega
kütusekulu norm
oskab keegi kommenteerida?
Tiit
Registreerunud 23.03.07
Auto: audi 100 avant tdi
postitati 12.01.08 15:10 Tsiteeri
vale termostaat?
must1.9tdb4audi
Registreerunud 25.09.05
Auto: audi a6 2.5tdi Q
postitati 15.01.08 19:45 Tsiteeri
õnneks ma pole siis ainuke kellel selline tore jama saksa autos öeldi et praak termostaad forsist ostetud 87c peale kirjutatud ja soojaks ei lähe suvel saab ainult 5 minutiks soojaks kui auto käib koha peal 10 min siis hakkad liikuma viskab 90 ja 5 minuti pärast on jälle väike nõks alla 70-ne kraadi
ferdinand
Registreerunud 17.01.03
Auto: 400,401,969
postitati 15.01.08 19:58 Tsiteeri
Algselt postitas: kosmoseklutt
njaa
Suts alla 37 on normaalne, mõnel inimesel ka natuke üle.:D
ringi vaadata ei viitsi üldse?
http://foorum.audiclub.ee/viewthread.php?tid=48141#pid284351
[PHP: 9.6% - SQL: 90.4%]
