Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - AUDI 200 134kw 85a.BLOW OFF
Pealkiri: AUDI 200 134kw 85a.BLOW OFF (Vastuseid: 11 | Vaatamisi: 1533)
lassekast
Registreerunud 07.12.06
Auto: Audi200 125kw,audi 200 134 kw,audi 100TQ 121 kw,audi 200 85 a kw 134+,audi 200 84a. 134kw
postitati 11.01.08 09:02 Tsiteeri
selline küsimus et igal turbo mootoril on blow off,olen kuulnud et mingi sisene blow off aga kus see siis asub, ette tänades
tarts
Registreerunud 25.09.02
postitati 11.01.08 09:05 Tsiteeri
ei ole sugugi kõigil, audidel üldse ei ole seda, on bypass. 10v turbokal ei ole bypassi ka.
Teemo
Registreerunud 15.10.05
Auto: Audi Quattro
postitati 11.01.08 09:13 Tsiteeri
Algselt postitas: lassekast
"Sisene" on tavaliselt wastegate. Audil on aga turboväline wastegate. Blow off'i ei kasutata Audil üldse, kui siis by-bass'i.
Kui tahad by-bass'i lisada, vaata 20v meeste teemasid, kuid põhimõtteliselt selle lisamine kindla käiguga kiirendamisel, midagi juurde ei anna.
Edit: tarts juba vastas!
Kaits
Registreerunud 01.03.03
Auto: RS 6 Avant
postitati 11.01.08 15:09 Tsiteeri
Peale by-passi paigaldamist hakkas kuidagi palju mugavamalt 10VT liikuma. Mina soovitan küll selle asja peale panna .
Peale käiguvahetust läheb turbo kiiremini pöördesse ja sellest ka tiba erksam minek. Mulle meeldib.
lassekast
postitati 11.01.08 16:08 Tsiteeri
Algselt postitas: Kaits
iga tahes tasub siis proovvida tänud
lassekast
postitati 11.01.08 16:10 Tsiteeri
aga kustkohast seda by--passi osta saab ja mis maksab
tarts
postitati 11.01.08 16:12 Tsiteeri
audi/vw esindus, forss, autoekspert. 350 - 400 EEK peaks olema.
kui valgast kohe ei leia ja tartus ka kohapeal ei ole, võid helistada, ma peaksin hetkel veel paariga plussis olema, ehk on vabu.
kahesajane
Registreerunud 22.10.04
Auto: 200TQ
postitati 16.01.08 20:32 Tsiteeri
Aga nüüd selline küssa, sellepärast on vist ennemgi vaieldud, ma neid klappide nimesid täpselt ei tea aga see mis siin kirjeldatud laseb ülerõhu jälle ringlusesse aga on ka neid mis lasevad õhu lihtsalt õue, et kumb siis parem oleks ?
MartinCS
Registreerunud 28.03.06
postitati 16.01.08 21:19 Tsiteeri
Kui see klapp asub peale õhulugejat, siis see, mis laseb õhu uuele ringile, mitte atmosfääri. Sest see õhk on loetud, aju arvestab selle kogusega, kui sa selle atmosfääri lased on segu vale.
Ehk siis audidel on by-pass, ehk see klapp mis laseb õhu ringlusse. See mis laseb õhu välja, seda nimetatakse blow-off'iks
kahesajane
Auto: 200TQ
postitati 18.01.08 07:51 Tsiteeri
kui nüüd seda pilti vaadata tekkis mõte, et see toru mis klapist tagasi turbo ette läheb, kas poleks parem kui see oleks nagu õhu liikumise suunas, sest praegu ta on ju õhusuunale vastu ?
lassekast
postitati 15.05.08 06:39 Tsiteeri
kas siis mina peaks nii tegema mul KG mootor
http://nagi.ee/photos/Audi200q/5613409/
Kaits
Auto: RS 6 Avant
postitati 15.05.08 14:04 Tsiteeri
Pildil oleva MC1 mootori üks by-passi voolik on võetud cooleri vannist (roheline voolik). KG-l on sama koha peal juba originaalis väljavõte wastegate'i alumisse kambrisse. Kui selle koha kõrval on veel ruumi ühele vooliku väljavõtule, siis saab ka nii teha, aga üldiselt seal väga palju ruumi pole.
[PHP: 0.2% - SQL: 99.8%]
