Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - õli kogus?
Pealkiri: õli kogus? (Vastuseid: 11 | Vaatamisi: 1511)
olbert
Registreerunud 13.01.06
Auto: Golf IV 1,9TDi 4Motion Variant
postitati 06.01.08 09:36 Tsiteeri
õli kogus?
ma kas ei oska otsida või lihtsalt ei leia aga soov oleks vahetada kastis ja ka sildades õli. niisiis kes oskab õelda, kui palju käib kastis õli ja palju sildadesse läheb ja mis kõige tähsam, mis õli oleks parim.
autoks siis S6 1995 2,2
kui on teema vales kohas või juba olemas siis paluks kustudada või suunata sinna.
tänud ikkagi ;)
alar008
Registreerunud 05.11.06
Auto: Audi A6 3.0 Q, Audi Q7 3.0 171kw
postitati 06.01.08 10:51 Tsiteeri
mis kastiga tegu.kas automaat või manuaal
moosisco
Registreerunud 05.02.07
Auto: Saab 9-5 2,0 T; Opel Frontera 2,4; Ssangyong Musso 3,2
postitati 06.01.08 11:22 Tsiteeri
Kogused-värgid saad siit teada.
Tähelepanu! Tegemist on Quattroga, enne tarvitamist pidada nõu arsti või apteekriga.
olbert
postitati 06.01.08 11:45 Tsiteeri
Algselt postitas: alar008
sorry, 5-ne manuaal. unustasin ennist.
alar008
postitati 06.01.08 14:03 Tsiteeri
Saatsin sulle meili peale.Loodan,et on abiks.
alar008
postitati 06.01.08 14:22 Tsiteeri
Paraku tundub,et mail ei toimi.
olbert
postitati 06.01.08 15:53 Tsiteeri
msn oli abiks. tänud
olbert
postitati 10.01.08 17:07 Tsiteeri
nüüd õlid olemas aga ma ei leia ülesse seda auku, kust ma pean õli tagasi sisse laskma. jutt siis kasti õli vahetusest.
esisillas on küll olemas nii sisse kui välja laskmise koht. ja tagasillas lausa kaks kohta, kust välja saab lasta õli.
aga miks ma ei leia seda kohta, kust kastile saaks õli tagasi sisse panna. kas on võimalik, et kastiõli ja esisilla õli käivad mõlemad esisilla sisselaske august.
Kuule mees, ega sa rahvastepalli ei mängi, kus sul mitu elu on!
www.alunaut.ee kõik alumiiniumi tööd (tegemist siis merealumiiniumiga)
olbert
postitati 11.01.08 19:47 Tsiteeri
kas keegi ei oska aidata siis ? :(
jõuvanker
Registreerunud 21.03.03
postitati 11.01.08 19:53 Tsiteeri
Algselt postitas: olbert
Esisilladiffril on käigukastiga ühine õlikarter, vaata, ühelpool pooltelje välatulemis kohast kasti küljel on kork, sealt valad sisse. Dagadiffris mõlemad alumised punnid lahti ja sisse valad samamoodi ühel pool asuvast õlikorgiavast ,mis on siis pooltelje väljatulemisava juures. Uuri.
olbert
postitati 11.01.08 21:24 Tsiteeri
Algselt postitas: jõuvanker
tänan. ootasingi seda vastust. ei tahtnud enne kastist ja esisillast õli välja lasta, kuna kahtlesin selles. nüüd ei muud, kui õli vahetama. mitte küll kohe :)
tänud suured ;)
olbert
postitati 27.01.08 19:54 Tsiteeri
nüüd õlid vahetatud ja tuju kohe kena :)
[PHP: 44.1% - SQL: 55.9%]
