Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - c4 generaatori rihma pingutus
Pealkiri: c4 generaatori rihma pingutus (Vastuseid: 2 | Vaatamisi: 844)
cescor
Registreerunud 05.05.04
Auto: Audi 100 2,5TDI
postitati 02.12.07 10:45 Tsiteeri
Sai siis ostetud lammutusest uus generaatori rihma pingutus rullik koos pingutiga (amordi variant)
Lammutuses oli see keskelt pooleks võetud. Polt oli olemas, koos seibiga.
Kokku pannes tundus, nagu peaks seal sees veel mingi puks käima? On keegi lammutanud seda?
vreps
Registreerunud 04.10.07
Auto: Audi 100 2,5tdi nüüdseks ajalugu
postitati 02.12.07 11:48 Tsiteeri
Äkki saad pildi panna, siis vaatab mis puudu on.
cescor
postitati 02.12.07 12:08 Tsiteeri
Algselt postitas: vreps
Hetkel autol küljes ja pilti pole ;(
aga http://www.elcats.ru/audi/parts.asp?uid=46D96F21-C2C8-46CA-931B-8E5BCF126EE9&mdl=168&unit=DB808A0F
nr 21 siis
Kui keskelt pooleks võtta, siis on see õhuke seib ja servas kummtihend. Rohkem pole midagi. Just ümerringi jääb vahe sisse. Kui kinni keerata jääb õrnalt loksuma.
[PHP: 39.9% - SQL: 60.1%]
