Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Sidurisüsteemi eemaldamine
Pealkiri: Sidurisüsteemi eemaldamine (Vastuseid: 2 | Vaatamisi: 898)
tryku
Registreerunud 04.01.05
postitati 19.11.07 19:30 Tsiteeri
Selline probleem siis, et ostsin teise käigukasti sigarile(KU-le) ning seal on kõik sidurisüsteem küljest ära keeratud, kaasa arvatud see osa, kuhu läheb sidurivoolik. Survelaagri jms jura sain kergesti kätte, kuid kuidas eemaldada see siduri hüdrauliline pool. Ühtegi polti vms ei paista, ei julge julmalt lüüa ka.
ferdinand
Registreerunud 17.01.03
Auto: 400,401,969
postitati 19.11.07 19:35 Tsiteeri
Osadel vanematel kastiversioonidel kinnitub siduri töösilinder õõnsa tihvtiga mis tuleb välja lüüa.
tryku
postitati 22.11.07 17:29 Tsiteeri
Mul oligi niimoodi, suured tänud :)
[PHP: 39.0% - SQL: 61.0%]
