Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - ABS aegajalt töötab ja aegajalt mitte
Pealkiri: ABS aegajalt töötab ja aegajalt mitte (Vastuseid: 8 | Vaatamisi: 1251)
arrow110
Registreerunud 01.08.07
postitati 18.11.07 19:43 Tsiteeri
Tere mõttekaaslased!
Mure järgmine. Umbes paar nädalat tagasi hakkas armatuuris põlema ABS-i kollane tuli ja samal ajal süttis ka punast värvi (!) tuli. ABS ise aga töötas edasi. Tuli ei süttinud kohe peale auto käivitamist, vaid tahtis saada natuke pidurdamist. Samas tule süttimine oli ülimalt kaootiline. Vahel võisin terve päeva sõita ja tuli ei süttinud kordagi, siis jälle hakkas kohe peale esimest pidurdust põlema.
Vahepeal võtsin ABS-i kaitsme pesast välja ja pani tagasi. Siis sain 2 päeva ilma tuledeta sõita.
Nüüd on aga asjalood nii kaugel, et kuigi tuli põleb endiselt kaootiliselt, kaob tule süttimisega iga kord ka ABS ise ära.
Oskab keegi nõu anda?
Edit: unustasin öelda, et tegemist 1999 juuli A4 Avantiga
juks11
postitati 18.11.07 20:13 Tsiteeri
Algselt postitas: arrow110
ABS'i plokk vajab remont.
prix666
Registreerunud 24.04.06
Auto: A6Q
postitati 18.11.07 20:48 Tsiteeri
ei pruugi, oma masinal ka tegi sama trikki ja asi oli anduris, millele olid kogunenud poolpiduselt poolteljeotsalt rauakübemed mis takistasid tal lugemist.
Nahksisud ning istmete parandustööd.
Roolide nahatamine, käigukangikotid, -nupud. Kõik võimalike detailide katmine, piilarid, laed, kosoolid. Kaatrite sisud ning tsikli istmed, baaride sisustusest lennuki salongideni. Küsi hinda !
arrow110
postitati 20.11.07 12:24 Tsiteeri
Olen ise ka pakutud variantide peale mõelnud, aga kuna võimalikke vea asukohti on nii palju, siis oleks ehk mõtekam diagnostikasse minna? Või ei näita see ära, kus täpselt viga on?
Kui aga minna, siis kuhu?
juks11
postitati 20.11.07 12:27 Tsiteeri
Esiteks, kui põleb ka punane hüüumärk siis viga ei ole anduris, vaid plokis endas!
Tule meilt läbi ning asi selge!
Dixi
Registreerunud 13.02.05
Auto: Audi A6
postitati 20.11.07 12:32 Tsiteeri
Saatsin U2U.
arrow110
postitati 23.11.07 11:28 Tsiteeri
tänud pakkujatele, ootan ära palgapäeva ja jõulupreemiad, kui ned ikka tulevad, lubati, et tulevad...:), siis ilmselt diagnostikasse
waic
Registreerunud 16.05.05
Auto: Allroad 3.0 + A5 sportback 3.0
postitati 23.11.07 20:58 Tsiteeri
TÄPSELT samad sümptomid leidsid mul aset suvekuudel, aitas abs-i aju remont väärtuses 3k , odavamalt on vist raske seda korda saada,kuna omalkäel lahti võtta suht riskantne, sest vabatahtlikult see blokk lahti ei käi ja ära lõhkuda ka ei riskinud,kuigi on kahtlus,et seal sees tekivad lihtsalt aja jooksul mingid "külmjooted" ,mis mingil ajahetkel enam ühendust ei anna ning mille ületinutamisel asjatundja poolt probleemid kaovad.... :)
Remont ise kestis suht lühikest aega ( 1 õhtu )
Mind aitas audiclubiline kasutajanimega Dixi,kes konkreetse asjaga tegeleb, antud teemas ka "otsing" suhtpalju abiks :)
mikk1984
Registreerunud 29.11.07
postitati 22.03.08 08:30 Tsiteeri
tean ühte head elekrikut kes mul selle abs aju võrreldes teistega ikka väga odavalt korda tegi külmjooteid oli mul seal 3.
[PHP: 39.5% - SQL: 60.5%]
