Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Probleem A4 mootori pööretega.
Pealkiri: Probleem A4 mootori pööretega. (Vastuseid: 5 | Vaatamisi: 1184)
Tanel26
Registreerunud 22.09.07
Auto: A6 2004a. 2,5TDI Quattro Bau 132KW
postitati 04.10.07 21:11 Tsiteeri
Audi A4 Avant 2.6 96a.
Probleem seisneb selles et kohati jäävad mootori pöörded 1500 peale seisma ja mõne aja möödudes kõik jälle normaliseerub. Milles võib probleem olla äkki kellegil on sellise asjaga kogemusi olnud?
darkSlide
Registreerunud 11.11.04
Auto: Audi A4 1.8
postitati 05.10.07 07:48 Tsiteeri
probleem võib tekkida väga paljudest asjadest
Abiks otsing: "pööreded kõiguvad"
erki.t
Registreerunud 06.07.06
Auto: Got burger? (Jeep)
postitati 05.10.07 15:26 Tsiteeri
ehk aitaks üks TBA ?
ülks
Registreerunud 04.12.04
postitati 05.10.07 15:42 Tsiteeri
http://foorum.audiclub.ee/viewthread.php?tid=43642#pid264117
http://foorum.audiclub.ee/viewthread.php?tid=36920#pid236201
www.teemetünni.ee
jansadj
Registreerunud 07.08.07
Auto: a6 2.8 /2001
postitati 05.10.07 20:08 Tsiteeri
siin võib jah mitu viga olla kuid võimalik et aitab ka gaasiklapi puhastus võimalik ka lisaõhk või lambda!
kõigealustuseks aga panna ka diag juhtmed külge ja vaadata mis vigu ka näitab
Tanel26
postitati 08.10.07 05:53 Tsiteeri
TBA?
[PHP: 38.6% - SQL: 61.4%]
