Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - A4 turbo ja õlituli
Pealkiri: A4 turbo ja õlituli (Vastuseid: 0 | Vaatamisi: 837)
zimi
Registreerunud 04.10.07
postitati 04.10.07 07:20 Tsiteeri
A4 turbo ja õlituli
Tere ,
Ostsin paar nädalat tagasi kasutatud A4 ( 1999a , 2.5 TDI 110 kw ).
Paar päeva tagasi tankisin peaegu tühja paagi täis , käivitasin ja õlituli armatuuril hakkas põlema.Lisaks kadus turbo.Mõne tunni pärast põles õlituli edasi ( kuigi õli oli natuke alla Max-i )ja turbo taastus mingil määral.Veel mõne tunni pärast kustus ka õlituluke ära.Sõitsin rõõmsalt mõned päevad ja jälle hakkas õlituli põlema , pärast varda kontrolli ( kõik normis ) kustus tuli jälle ära.Kas Audidel ongi selline meeldetuletus õli kontrollida iga paari päeva tagant või on tegemist elektroonika / anduri veaga? :)
Lisaks sellele on turbo nagu kaotanud osa jõust ( sümboolselt hinnates töötab nagu umbes 75% jõudlusega).
Kas need sündmused on omavahel seotud või on lihtsalt õlituli p***s ja turbo tahaks puhastust/vahetust/remonti?
Peale selle veel ,uurisin siin foorumis A4 manuaali ja leidsin ,et tuled peaks nagu automaatselt ikka põlema minema aga mul pole see siiamaani õnnestunud , ikka mölla kangiga enne ja pärast sõitu :)
Vabandust( võimalike ) rumalate küsimuste pärast ,
ette tänades,
Siim
[PHP: 39.7% - SQL: 60.3%]
