Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Deceleration cut-off klapp
Pealkiri: Deceleration cut-off klapp (Vastuseid: 3 | Vaatamisi: 1023)
ITmees
Registreerunud 26.05.04
Auto: Audi 100 CS Avant
postitati 12.09.07 12:15 Tsiteeri
Tere.
(Vabandust ei hakanud seda klapinimetust ise suvaliselt tõlkima.)
Mul küsimus, mis juhib (kas mõni reelee?) deceleration cut-off klappi, mis asub õhupuhasti küljes. Asi nimelt selles, et kui mootori pöörded tõsta rahulikult, siis ~1500 pöörde juures hakkab mootor jõnksutama (see klapp hakkab tööle kinni/lahti). Edasi pöördeid tõsted see kaob. Kui nüüd kiirendades pöördeid tõsta, siis masin töötab normaalselt ja kõik on korras. Aga rahulikult selles vahemikus jõnksutab. Kui nüüd selle klapi juhe lahti ühendada, siis masin töötab normaalselt nii rahulikult kui ka kiirendades. Ka käivitub auto nii soojalt kui külmaslt normaalselt. Kuid õrnalt oleks nagu tunda jõuetust kiirendusel.
Klapp regeerib ise õigesti, tester näitab ka pinge kiikumist juhtmetes 0-14V vahel ja vastavalt sellel ka klapp regeerib.
Mootoriks on KU -87.
On kellegil mingeid kogemusi sellega?
jokker
Registreerunud 10.07.05
Auto: A6 '96 ABK
postitati 12.09.07 12:18 Tsiteeri
klapi enda töö peaks olema kütuse "kraanide" kinni keeramine aeglustamisel.
joyrider
Kaits
Registreerunud 01.03.03
Auto: RS 6 Avant
postitati 12.09.07 12:21 Tsiteeri
Kuna see klapp töötab pea samal põhimõttel kui by-pass klapp, siis kas äkki võib viga olla selles, et klapis membraan katki/kinni vms?
Juhitakse vist kuidagi tühikäigu lüliti ja pöörete järgi (tahho signaal?)
Mõte on tal selles, et käiguga pidurdamisel juhib õhuvoolu õhulugejast mööda. Õhulugeja plaat vajub alla -> kütust silindritesse ei anta.
ITmees
postitati 12.09.07 12:25 Tsiteeri
Kahtlustan isegi seda, kuid mis nüüd selle tööd juhuib ma pole aru veel saanud. Kas mingi andur või siis relee jamab ja sealt ka see jõnksutamine.
Ma olen aru saanud, et klapp töötab nii nagu peab ja lasebki õhku lisaks kui talle pinge peale antakse. Kuid miks see pinge nii kõikuv on?
Hetkel lihtsalt tõmbasin juhtme lahti - vähemalt sõitmist ei sega.
[PHP: 0.5% - SQL: 99.5%]
