Pealkiri: Millist mootoriõli kasutada...TDI (Vastuseid: 6 | Vaatamisi: 2499)
hamlet
Registreerunud 29.03.06
postitati 09.09.07 19:51 Tsiteeri
...kas Valvoline Durablend Diesel (5W-40)
...või Valvoline MaxLife Diesel (10W-40)
auto sõitnud üle 220000km (loodan et pole keritud).1.9TDI 1999a (vin`i järgi peaks olema 2000a mudel)
...või on sinna veel midagi paremat Valvoline toodangust? (hetkel sees mingi poolsünt eelmise omaniku jutu järgi)
juks11
postitati 09.09.07 19:52 Tsiteeri
Algselt postitas: hamlet
On tegu pumppihusti mootoriga või ei!?
equilibrium
Registreerunud 10.04.06
postitati 09.09.07 20:33 Tsiteeri
http://lubricantadvisor.valvolineeurope.com/
hamlet
postitati 09.09.07 20:40 Tsiteeri
Algselt postitas: equilibrium
kas siis need:Engine oil with filter 3,80 Litres
Engine oil specification VW 505 00
Engine oil specification Longlife VW 506 00 ?
Raiot
Registreerunud 06.12.06
Auto: A4 Avant 1.9TDI 81 kW, B4 2,0 85 kW, B3 1,9E 83kW
postitati 11.09.07 11:59 Tsiteeri
Mul 1997 a4 1,9tdi 81kw ja mina kasutan Mobil Rally Formula 5w-50 mida mu tuttav mehaanik soovitas ja ise kasutab, et pidavat talvel paremini käivituma!
hamlet
postitati 12.09.07 08:40 Tsiteeri
Mis see AVG tähendab?
Põder
Registreerunud 04.08.03
Auto: Impreza GT 555
postitati 14.09.07 21:25 Tsiteeri
Oman 1996 A4 1.9TDi 81kw ja kasutan Liqui Moly Synthoil High Tech 5 W-40
[img]http://www.liqui-moly.de/web/lmhomeen.nsf/FCF4E77234E1940BC1256C4C004907E0/$FILE/1307.jpg[/img]
Energy-conserving oil for today’s engines. Reduces oil and fuel consumption. Optimum lubrication even under extreme operating conditions. With thermally-stable wide-range viscosity. Immediate lubrication during cold starts and optimum oil pressure at all engine speeds. Lubrication is also reliably maintained at extreme temperatures. Optimum engine performance. Improved protection against wear and extended service life for the engine. Tested on catalytic converters and turbochargers.
Operational area: Year-round oil for petrol and Diesel engines. Especially suitable where there are long intervals between oil changes andextreme demands.
Car manufacturer´s approval: API SM / CF; ACEA A3-98/B3-98 Issue2/B4-98; BMW Longlife-98, MB 229.1, MB 229.3, VW 502.00, 505.00, Porsche alle Fahrzeuge
[PHP: 8.2% - SQL: 91.8%]
