Pealkiri: Vajaks abi kliima veakoodide asjus! (Vastuseid: 0 | Vaatamisi: 1086)
vuchmann
Registreerunud 21.05.06
Auto: CLS 55 AMG 400 kW
postitati 06.08.07 14:22 Tsiteeri
Autoks siis audi 100 2.8 92a.
Kliima näitab selliseid nr-d:
5.1 Outside Air (Ambient) Temperature Sensor, front, static open.Value supplied by Temp. Sensor is used if sensor fails
6.1 Engine Coolant Temperature (ECT), A/C static open.Engine Coolant Temperature is calculated is sensor should fail or is not installed; diagnosis occurs only above 0 degrees Celsius
7.3 Ambient Temperature Sensor at Fresh Air Blower, sporadic open
8.3 Temperature Regulator Flap Motor Potentiometer, sporadic open
8.5 Temperature Regulator Flap, static block.Motor is cycled; software attempts to eliminate block
8.6 Temperature Regulator Flap Motor Potentiometer, malfunction
11.1 Central Flap Motor Potentiometer, static open.Central Flap Motor will no longer be controlled automatically; manual adjustment only
11.5 Central Flap, static block.Motor is cycled; software attempts to eliminate block
11.6 Central Flap Motor Potentiometer, malfunction
15.3 Air Flow Flap Motor Potentiometer, sporadic open
22.1 A/C Refrigerant High Pressure Switch, static open.Compressor remains off until switch closes
29.4 Belt slip detection "hard", sporadic
Ühesõnaga,mida need Eesti keeles tähendavad.
[PHP: 18.2% - SQL: 81.8%]
