Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - K:mis numbri all on abs-i kaitse
Pealkiri: K:mis numbri all on abs-i kaitse (Vastuseid: 2 | Vaatamisi: 1186)
bam
Registreerunud 21.09.06
Auto: A8 D2 4,2 220kw. A6 C4 2,8 142kw q man.
postitati 28.06.07 12:02 Tsiteeri
mis numbri all on abs-i kaitse (100 c4 2,8 quattro `93)
oskab keegi kohe peast õelda mis nr. all see kaitsmeplokis on?
võtaks üldse vahelt ära vahepeal.
nimelt pidurdamisel (väheke enne päris peatumist) imelik "krosin".
ka õrnalt pidurdades,mitte järsult.
tekkis peale abs-i anduri vahetust,ennem nagu ei olnud sedasi
Dixi
Registreerunud 13.02.05
Auto: Audi A6
postitati 28.06.07 12:23 Tsiteeri
Võiks ju ikka andurit uurida, mitte kaitset välja võtma hakata.
bam
postitati 28.06.07 12:31 Tsiteeri
esialgu võtaks kaitsme välja,aga jah peab seda anduri värki vist ka uurima.kai aega rohkem on.
on kellelgi sama jama muidu olnud ka?
[PHP: 49.9% - SQL: 50.1%]
