Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - ebameeldiv olukord... LUKKU!
Pealkiri: ebameeldiv olukord... LUKKU! (Vastuseid: 8 | Vaatamisi: 1448)
hamlet
Registreerunud 29.03.06
postitati 23.03.07 17:05
....juhtus mul täna Tartus Lõunakeskuse parklas:Tagurdasin parklast välja-eelnevalt veendudes, et kummaltkilt poolt tee vaba,jõudsin nii kuni 50cm tagurdad, kui üks tütarlaps tuli mulle tagant riivamisi sisse suure kiirusega nii et sai pidama alles minust mõõda sõites.Kiirus pidi tal ikka korralik olema, sest tuli ristmikult ja mina parkisin ristmikult u.15m kaugusel.Norm kiiruse juures peaks ju nägema ja pidurdama.Ma ei saanud enam midagit teha nii väikese maa tagant (parklast välja tagurdades oli ju tee puhas).Tegime(teine kannatanu tegi foto-kuna tal kaamera oli)foto ja lubas kindlustusse saata.muideks varikatuse kohal on seal kaamera -ei tea ainult kas salvestab midagit.
..Probleem selles et sõitsime kindlustusse mitte ei jäänud politseid ootama.Kindlustuses õeldi selle kirjelduse peale, et mina süüdlane.
...Nüüd probleem selles, et kas on võimalik veel midagi ette võtta või peab sellega leppima?
Marek1
Registreerunud 20.04.04
Auto: A6 Avant 2012 & VW Passat 2011
postitati 23.03.07 17:14
Kuna politsei ei käinud kohapeal ja ei mõõtnud ära pidurdusjälgi, siis sellega seoses kehtib Eesti vabariigis selline seadus, et tagurdaja on alati süüdi. Kahjuks on see nii.:(
ferdinand
Registreerunud 17.01.03
Auto: 400,401,969
postitati 23.03.07 17:46
Algselt postitas: hamlet
Tagurdades peab jh paraku teistele teed andma, st ette võtta ei ole tõesti midagi. Kui just juhtuks hulgaliselt tunnistajaid olema, kes kõik väidavad, et teine auto tõesti 200km/h 30 alas sõitis, kuid ka siis läheb "parimal" juhul süü pooleks. Kui autod mõlemad iseseisvalt minema sõitsid siis ilmselt ei saanud siiski väga suurte kiirustega tegemist olla.
hamlet
Algselt postitas: Marek1
Eks ta ole. Polegi vist midagit teha.Kui see turvakaamera just midagit olulist ei näita.
Õnneks minu kahju väike -mõlk stangekattel,mida saab välja muljuda.Ilmselt mul tõuseb kindlustuse riskiaste.
...escorti vasak latern oli küll parajalt sodi.
...võibolla peaks hoiatama,et parklates tasuks ka väga tähelepanelik olla nende vanade fordidega ja japsidega-eks neile meeltmõõda see rammimine.
mind häirib tegelt see, et kuidas on siis võimalik ohutult parklast välja saada? kas tagumine käiksisse ja ruttu gaas põhja ja siis käiguvahetus ja uuesti gaas põhja ja siis ohe ja ristimärk ette lüüa? :-DDD
...või peaks tegelt liiklusseadust muutma parkijate turvalisuse huvides?
jan-kos
Registreerunud 23.04.03
postitati 23.03.07 18:18
Eeskiri ütleb et tuleb kasutada teise isiku abi.
cmp
Registreerunud 18.05.06
postitati 23.03.07 19:12
eks muidugi on kehva tagurdada, kui midagi ei näe... tagurdad veidi, pidurdad - vaatad uuesti ja sedasi niikaua kuni näed.
isegi kui teine kihutab, on väljatagurdaja süüdi.
eks õnnetus on kahe poole vaheline asi, mõlemad on omamoodi kannatajad, eks escorti foorumis kostab täna kaebamist, kuidas "üks jobu täna mulle ette tagurdas" :P
hamlet
postitati 23.03.07 19:24
Algselt postitas: cmp
..nii ta on!
..mehed ei nuta!
.."Valge Kurg" teab kuidas meest lohutada :-D
LUKKU!
wookie
Registreerunud 21.02.07
postitati 23.03.07 20:06
§105. Tagurdamisel ei tohi juht ohustada ega takistada teist liiklejat.
(1) Anda teed (mitte takistada) all mõistetakse nõuet, et liikleja ei jätkaks ega alustaks liikumist ega teeks mingeid manöövreid, mis võiksid sundida teist liiklejat muutma liikumissuunda või -kiirust.
Liikleja, kellel on kohustus anda teed, peab sellest selgelt märku andma kiiruse vähendamisega või sujuva peatumisega.
Kui sa nüüd väidaks, et kokkupõrke hetkel oli sinu kiirus 0, siis võiks IMHO tekkida võimalus vaidluseks, kuna sa sisuliselt oled täitnud teeandmise (mitte takistamise) nõude - sujuvalt peatunud.
Eriti veel, kui LE ei täpsusta, misasi on tagurdamine....
kas2par
Registreerunud 25.07.05
Auto: S4 Avant 2.7BiT 2000a.
postitati 23.03.07 23:38
jälle escort.... mul allergia punaste escortite vastu. alles 3 nädalat tagasi tapsin 1 ära:D Tuli peateele ette
[PHP: 45.1% - SQL: 54.9%]
