Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Piljard Tartus kolmapäeval, 31. jaanuaril järelkaja
Pealkiri: Piljard Tartus kolmapäeval, 31. jaanuaril järelkaja (Vastuseid: 11 | Vaatamisi: 2773)
Kirsa
Registreerunud 20.05.04
Auto: Audi Coupe Q 20v
postitati 31.01.07 23:44 Tsiteeri
Et kui ausalt ära rääkida, siis tuleb alustada sellest, et klubiliige Äss läks poodi ja ostis kirve. Järgmisena tuli plaan selle kirvega midagi ette võtta - ega's midagi järvele jääd raiuma. Tulemuseks kiire kõne mune koksivatele klubilistele, et jääd on poole kirvevarre jagu.
Selle peale tehti piljardiga kiirelt 1:0 ja suunduti järvele. :))
Ülejäänust räägivad Riimaku pildid(kui ta kunagi ärkab) ja tühjad bensiinipaagid. ;D
Jää pidas küll. Üks võõras M klassi mersu vajus yhe rattaga jääst läbi, aga ei ole vaja igast roostikust läbi sõita. :)
Martinez
Registreerunud 22.09.06
Auto: B5 1.8TQ, Passat B7, DL 1000
postitati 01.02.07 05:23 Tsiteeri
deem
oleks pidand ka sealt mune koksimast ikka järvele tulema
väike kadedus puges praegu sisse :(:cool:
Menthor
Registreerunud 11.08.03
Auto: Audid
postitati 01.02.07 05:57 Tsiteeri
Väga mõnus oli :cool: Järgmine kord jääle minnes tuleb ikka paagid kohe täis lasta :D Piljard oli ka hea... samas rahvast oleks võinud ju natuke rohkem olla.
Jääb nüüd siis järgmist üritust ootama :)
poleoluline
Registreerunud 25.05.06
Auto: A8 4,2 Q
postitati 01.02.07 07:03 Tsiteeri
Kuigi mina pole "sõidumees" leidsin hommikul auto ninaalt mingid kõrred miss meenutasid pilliroogu (ilmselt Kirsa topitud):o :cool:
Ja järgmine kord võiks grillimaterjali kah jääle kaasata :)
kas2par
Registreerunud 25.07.05
Auto: S4 Avant 2.7BiT 2000a.
postitati 01.02.07 07:22 Tsiteeri
millisest järvest jutt käib? ja kas täna õhtul ka minnakse testima?
Riimak
Registreerunud 28.07.06
Auto: Gooooooolf / Riisirakett
postitati 01.02.07 10:00 Tsiteeri
niisis, niisis.
ma ärkasin üles ning siin on ka pildid
AC piljard + jäärada
pilte on muudetud ainult niipalju, et suurust on väiksem. Mudu on üleval iga klõps mis tehti. Ning kui keegi arvab, et ma olen kole seal pildil siis noh, ütleks selle peale, et meie näemegi sind sellisena nagu sa pildil oled :P
ehk siis, tsenseerimata kujul on KÕIK pildid üleval, olenemata kas tuli pilt välja või mitte.
ja millal kordame?
Audi499
Registreerunud 07.12.04
Auto: A6 c7
postitati 01.02.07 15:42 Tsiteeri
kus te seda jääd siis leidsite???
Kuna uuesti??
kas2par
postitati 01.02.07 16:05 Tsiteeri
ei ole mõtet kodus passida, tuleb sinna ülenurme lähedale soole minna. keegi veel?
Soyer
Registreerunud 14.06.05
postitati 01.02.07 17:01 Tsiteeri
Mul homme vaba päev. Äkki keegi juhatab sinna jääpeale.
lorenzo
Registreerunud 05.11.06
Auto: B7 avant quattro, 2x 82' Ford Capri
postitati 01.02.07 17:47 Tsiteeri
ai *****
Ma arvasin et see soo seal kuivendati ära, aga ei olegi seda tehtud vist. Peab ka ära käima.
Kes ei tea kus see asub, siis pilt asub siin.
Pildist nii palju et algus punktiks on märgitud Võru-Ringtee rist (seda peaks küll iga üks teadma)sõita tuleb siis Roiu suunas ja lõpp on peale Pori jõe ületamist u. 0,5-1 km.
Paremal pool teed on üksik suur puu mille kõrvalt viib tee soo peale
kas2par
postitati 01.02.07 18:17 Tsiteeri
jää korralik ja sile. lamellimeeste jaoks vast liigagi libe. tasub ära proovida. minge niitge ka natuke pilliroogu:D
äss
ac aasta auto 2011 võitja
Registreerunud 23.03.04
Auto: 2x 1,8t ja masuudipress
postitati 01.02.07 22:18 Tsiteeri
Algselt postitas: kas2par
naela jaoks oli ka eile natuke liiga libe :D .. täna oli juba parem.
Algselt postitas: Audi499
Kuna uuesti??
http://foorum.audiclub.ee/viewthread.php?tid=36277
[PHP: 12.0% - SQL: 88.0%]
