Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - K: 1994 80 B4 Avandi esimesed kõlarid
Pealkiri: K: 1994 80 B4 Avandi esimesed kõlarid (Vastuseid: 4 | Vaatamisi: 1450)
Vincento
Registreerunud 18.11.05
Auto: Audi 80 B4 Avant
postitati 05.12.06 17:20 Tsiteeri
Küsimus selline, et kuidas pääseda ligi esimestele kõlaritele, mis asuvad armatuuri sees?
äss
ac aasta auto 2011 võitja
Registreerunud 23.03.04
Auto: 2x 1,8t ja masuudipress
postitati 05.12.06 17:23 Tsiteeri
kanguta kaan maha
janxs
Registreerunud 09.11.06
Auto: audi 80 quattro 2,0. 101kw.
postitati 05.12.06 17:24 Tsiteeri
Kõlari kate maha ja kõlari kruvid lahti ja käes ta onngi.
Vincento
postitati 05.12.06 17:30 Tsiteeri
Tohohh...nii lihtne ongi ...tnx ;)
ado
Registreerunud 17.07.04
postitati 05.12.06 19:03 Tsiteeri
Algselt postitas: janxs
Mina enda b4 93a sedaanist ei leidnud ühtegi kruvi
Katted ning elemendid olid mingi nätsuga kinni...:D
[PHP: 29.0% - SQL: 71.0%]
