Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Coilover vedrustus S2 Coupe-le - kust?
Pealkiri: Coilover vedrustus S2 Coupe-le - kust? (Vastuseid: 4 | Vaatamisi: 1672)
TT
Registreerunud 08.06.04
postitati 25.11.06 12:42 Tsiteeri
Tere
Kes Eestis võiks pakkud KW või FK Automotive coilover vedrustust kupeele (või mõne muu firma oma)?
Vedrustus peks olema mõeldud konkreetsele autole - tean, et lynx tegi kannud ja taldrikud ringi Bilsude pärast.
Plaanin enda autole keval Coilid alla panna, et vajadusel saaks ka mõne OT kaasa teha.
Või oleks mõtekas hoopis leida kusagilt kvaliteetsed madaldusvedrud ja lisaks esimestele reguleeritavatele amortidele ka taha regullitavad osta?
Praegu on autol all uued tehase vedrud, ees uued Koni kollased ja taga uued Bilsu, mittereguleeritavad, originaalvedrustusele mõeldud amordid.
Rax
Registreerunud 04.06.03
postitati 25.11.06 13:57 Tsiteeri
Tartus tuttav tegeleb sellega, hind oli ~1000euri komplekt, FK- automotive.
TT
postitati 25.11.06 18:33 Tsiteeri
Tänan - hind on hea;) võtan siis sinuga ühendust.
lynx
Registreerunud 15.10.02
Auto: Audi
postitati 25.11.06 19:10 Tsiteeri
kusjuures ma ei teinud coile bilsude pärast ümber. St. oleks võinud kasutada ükskõik milliseid amorte seal. Kuna koni sport oli juba eelmise auto peal proovitud ja paljud on bilsu sporti kiitnud, siis tahtsin lihtsalt proovida.
mis puutub FK Automotive tootesse, siis julgeksin natukene kahelda nendes. Kui endale kunagi X nimelisest firmast need tellisin, siis nad ei suutnud neid tarnida, lisaks lõpuks tuli välja, et tellitud sai üldse valed (mingi tavalised quattro omad). Ise nad ütlesid, et pole hullu . . . puurid siit, sealt midagi üle ja sobivad. S2l on esimesed ja tagumised amordid ühe jämedusega, tavalistel nelivedulistel need seda ei ole.
Mis KW puutub, siis nende kohta olen hea lugenud, kuid hinnad on neil ka vastavad. Kusjuures mul endal tehes ei tulnud kokkuvõttes need odavamad.
Üks asi mis mind kõige rohkem nende teiste coilide juures häirib on see, et kasutatakse kahte vedru. Vähemasti nii KW kui FK puhul S2 jaoks (iseasi ka FK teeb midagi S2 jaoks. Ainuüksi kataloog väidab neil, et S2 hakati tootma alates 86a). Et saada üks madaldus, näiteks ca. 35mm sobib kõik ideaalselt, kuid kui tahad veel madalamaks saada, tuleks see üks vedru lisaks eemaldada. Siis saab niipalju kui lubatakse. Okei, aga kui talv tuleb ja tahaks nulli tagasi saada . . . siis topi see lisavedru ikkagi sinna tagasi ja kas üleüldse saab tagasi päris nulli? See var. mida ise kasutan saab, isegi plussi saab ja miinust on rohkem kui vaja isegi läheb.
maitseasi loomulikult . . .
P.S> FK tahab amordi püstakuid vastutasuks saada, muidu on hind hoopis teisest puust, kas ka KW, seda ei tea.
genekas
Registreerunud 30.01.03
Auto: järgmist plaanimas
postitati 25.11.06 23:25 Tsiteeri
H&R võib olla otsimist väärt ehk ka...
[PHP: 43.9% - SQL: 56.1%]
