Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Müstiline kobin:-(
Pealkiri: Müstiline kobin:-( (Vastuseid: 13 | Vaatamisi: 2099)
MustMürsk
Registreerunud 08.11.06
postitati 09.11.06 00:08 Tsiteeri
Müstiline kobin:-(
Autoks A4, taga miski kobiseb, puksid pidid ok olema, mitmes töökojas lasin kontrollida, käisin ka ülevaatuspunktis ja lasin loksutada, puksid pidid täiesti ok olema, lasin ära vahetada amordipuksid, mitte mingeid vuhvleid pukse ei pannud, vaid korralikud kallid originaalid, ikka kobiseb. kobiseb just sellisel natuke treppis teel sõites ja nende igasuguste testimistega ja vahetamistega on kobin nagu valjemaks läinud:-( samas kõik laiutavad käsi:-( ostsin ka uued amordid ja läksin nendega töökotta vahetama, kui praegused olid alt ära, siis meistrimees ütles, et tema süda ei luba küll neid uusi alla panna, sest praegused pidid olema väga tugevad gaasiamordid??? samas see kobin on ainult veereva rattaga, kohapeal ainult üles või ainult alla vajutades ei kostu mitte mingit kobinat. pakuti veel, et laagrid läbi, laagrid kontrollitud, ei loksu ja kõik ok... viimastel päevadel on see muutunud juba nagu vaikseks kolinaks:-( tegin pagassi täiesti tühjaks ja sõitsin, sest arvasin, et äkkitsi miskit kuskil midagi lahti või midagi sellist, tulemust ei miskit. siis sõitsin veel nii, et panin sõbra taha pagassi ja lasin temal kuulata sõidu ajal, kobin/kolin pidi tulema kuskilt alt poolt tema sõnade järgi ja vasakult ja paremalt ja korraga jne... mis seal veel võib olla, on pakutud veel tagumisi pidurisadulaid ja klotse, mis võivad häält teha. samas nagu ei usu seda, sest ülevaatuspunktis ma lasin just tagumist silda kontrollida ja seal kõiki asju vaadata... ma ei teagi mida edasi teha, nõme on salongis seda kobinat/kolinat kuulata
kylaline90
Registreerunud 11.09.06
Auto: C4
postitati 09.11.06 07:06 Tsiteeri
sumps käib vastu põhja
indrekk
Registreerunud 04.09.06
Auto: 200 20v
postitati 09.11.06 11:44 Tsiteeri
vaata ega summuti liiga vabalt ei liigu all
Reix
Registreerunud 19.07.03
Auto: riisikas ja hamburger
postitati 09.11.06 14:27 Tsiteeri
Katalüsaator?
kes audis naerab, naerab paremini - http://foorum.audiclub.ee/viewthread.php?tid=2342
MustMürsk
postitati 10.11.06 05:09 Tsiteeri
sumps ega kat see ei ole, tõmbasime alt kõik vähegi liikuda võivad asjad nende plastik juhtmevitsadega tugevalt kinni. kobin tuleb ainult sõites ja ratastest. ma ei tea, aga ise kahtlustan tagasillapukse, kas need puksid võivad olla niimoodi läbi, et stendis ega kangutades aru ei saa?
Starr
Registreerunud 07.02.05
postitati 10.11.06 11:51 Tsiteeri
vaata oma pagass üle, et seal mingi vidin elama sõitmisel ei hakka.
kunagi oli tuttaval taoline teema, möllas ja uuris ka seda silda nii mis kole, a tegelt oli tung lahti ja tegi häält pagassis:D
edit: kõige kindlam viska pagass tühjaks ja proovi siis, kas ikka kobiseb
indrekk
Auto: 200 20v
postitati 10.11.06 15:35 Tsiteeri
pidurdades koliseb ka?
henri0
Registreerunud 04.12.05
postitati 11.11.06 06:57 Tsiteeri
Mul oli kunagi juhus oma b3 ga et midagi kolises esisillas nii carstop kui ka autopartner ütlesid et kõik on ok kuigi pärast tuli välja et raami puksid olid läbi. Ülevaatus punkt on nüüd küll viimane koht kust mõne targa mehe leiad.
MustMürsk
postitati 12.11.06 11:24 Tsiteeri
pidurdades kobiseb ka ja pagassi viskasin ka tühjaks ja sõitsin, panin veel sõbra pagassi ja kuulas seal, kuskilt alt tuleb kobin.... nüüd juba kindel plaan, lähen ja vahetan puksid ära, kuigi kõik kus käinud olen on õelnud, et puksid ok..
hunter
Registreerunud 07.05.05
Auto: Audi A4 Avant
postitati 12.11.06 19:32 Tsiteeri
tere
kontrolli amordi patjasid
MustMürsk
postitati 15.11.06 17:06 Tsiteeri
amordipadjad vahetatud, ei mõjunud. aga eile oli selline asi, sai tassitud pagassis vannitoa plaate, oli seal 31 pakki ja ühes pakis oli 0,5m2. ma ei tea palju see kõik kokku kaalus, aga kobin oli kadunud:-) pärast plaadid maha pannes ja tühjalt sõites oli "sõber" kobin jälle tagasi...
arro
Registreerunud 10.11.06
Auto: C3 quattro, C4 quattro
postitati 16.11.06 07:51 Tsiteeri
Algselt postitas: MustMürsk
Stendist siis niipalju et läksin ülevaatusele nii et rooliotsad olid läbi ja raamipuksid ka ning stend ei näidanud midagi. Ise algul pablasin et kas saan ikka läbi aga ennäe täiesti puhtalt.
Nii et stendi ära usu!!!!!:)
Black Rabbit
Registreerunud 12.08.04
Auto: Forester XT
postitati 16.11.06 10:10 Tsiteeri
See plaatide nali ei seleta kuidagi ka pukse ega ka pidurisadulaid, mis tõesti ka vahel kobina sisse annavad.
Otsisin endal suvel samamoodi seda kobinat ja vahetasin tagumised amordid, esimese pooltelje ja hunnik pisividinaid ära. Siis tuli välja, et allles vahetatud klotsidel oli mingi pingutusvedru ära lennanud ja need kobisesid piisavalt, et salongi kostuda. Samas ei pruugi sul viga selles olla. Eelmiselt autol sai tükk aega peale sumbuti vahetust seda sätitud, et kuskilt vastu ei käiks, sest ebatasasel teel või kurvis käis kuskilt vastu.
Tõsi on ka see, et ülevaatuspunktid ei avasta tihtipeale juba kulunud pukse, vaid enamasti neid, mis on väga hullus seisukorras.
juks11
postitati 16.11.06 10:16 Tsiteeri
Ülevaatuspunktidega on nii olnud mul, et viimase kuu jooksul olen ilusti (ilma ühegi veata) saanud läbi kahe Audiga, mille esisild on nii läbi olnud, et lausa ohtlik on sõita olnud...
[PHP: 42.9% - SQL: 57.1%]
