Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Pioneer DEH-P55BT
Pealkiri: Pioneer DEH-P55BT (Vastuseid: 28 | Vaatamisi: 4447)
Lumekass
Registreerunud 15.05.06
Auto: Hetkel Auditu
postitati 27.10.06 11:56 Tsiteeri
Pioneer DEH-P55BT
Tere! Plaan sellise makiga oma vana beta välja vahetada. On keegi juba soetanud, oskab kommentaare jagada? Disain ja toote omadused (sh Bluetooth) tunduvad OK.
Kiil
Registreerunud 03.02.03
Auto: Allroad C5
postitati 27.10.06 15:29 Tsiteeri
kle päris normaalne asi on,ise ostsin natuke aega tagasi. nupud ja ekraani saab punaseks ilusti panna ja heli saab timmida. bluetoothi handsfree värk on norm,telefon võib koguaeg taskus olla.
audi97
Registreerunud 05.07.06
Auto: Bmw 523i :(
postitati 27.10.06 16:54 Tsiteeri
tere,
mul omal selline varjant põhimõte sama ma usun..
http://www.mts.ee/catalog/product_info.php?cPath=21_60&products_id=227
Heli on ülihea, isegi originaalkõlaritega on super. Võimsus on väga hea (testitud). Blutooth on ülikõva sõna.. nii kui autosse istud ühendab automaatselt su telefoni ära ilma tel taskust välja võtmata. Kui keegi helistab, siis võtab automaatselt vastu.. kui su tel toetab häälkäsklusi siis saad ka häälega helistada, ütle ainult nimi ja juba kõllab ;) Üleüldiselt soovitan üldse pioneeri :D
edu!
postitati 28.10.06 14:25 Tsiteeri
Oskab ta üle Bluetoothi telefoni mälust/kaardilt MP3 ka välja sikutada?
leits
Registreerunud 12.02.06
Auto: Audi A4 2.5TDI V6 Avant
postitati 06.11.06 18:08 Tsiteeri
Mis hinnaga neid kasutatult liigub ja kas üldse liigub? Uue hind on tsips soolane minu jaoks :S
Huvitatud paintballist? Kontakteeru minuga: leits@ozkpaintball.ee
audi97
Auto: Bmw 523i :(
postitati 06.11.06 18:40 Tsiteeri
Algselt postitas: Black
vot mitte kohe ei oska küsimusele vastata:P
leits
postitati 07.12.06 19:28 Tsiteeri
proovisin sõbra autos asja, toda telefoni funktsiooni. Imo on see BS. Väga haigelt kajab nagu kui teine räägib ja ikka suht kõvasu peab rääkima et teine sind kuuleks
audi97
Auto: Bmw 523i :(
postitati 07.12.06 19:39 Tsiteeri
Algselt postitas: leits
Kaja saab eemaldada maki seadetest. Ja karjuma ei pea kui on õieti paigaldatud-mina räägin nagu ikka oma makiga. Aga seda peab tunnistama, et rääkida saab ainult see kelle nina all on mikker, kõrvalistuja ei saa. Ja see kõik võib oleneda ka telefonist
leits
postitati 24.12.06 10:12 Tsiteeri
Nonii, tellisin ka ikkagi ära :) Selline küsimus, et tal on ikka 2 RCA väljundit ju?
Noortehnik ja akustiak väidavad: • 3 RCA-väljundit
RCA Preout 2 (F + R or S/W) see pärilt tootja kodulehelt
?? mis tal sis on, 2 ikka?
Lumekass
Auto: Hetkel Auditu
postitati 24.12.06 10:34 Tsiteeri
RCA koha pealt ei oska midagi kosta, lasin enda oma audiopoes paigaldada. Usaldaksin siiski tootja andmeid. Helistamisega on jah pisut pahasti. Telefon SonyEricsson 750 kahjuks ei ühildu korralikult-tel.raamatut sisse sööta ei saa, seega näeb ainult sisseltulevat numbrit. Mikker on tõesti ainult selle ees istuja jaoks-ju hakkab siis tundlikum mikker välismüra neelama.Ühendada suudab makk telefoni siis, kui telefon on kõigile nähtav või ühendad iga jumala kord manuaalselt,kui autosse istud. Eelpool kirjutajale teadmiseks, et see telefonist lugusid ta kätte ei saa, seda võimaldab nõksa kallim mudel, mis maksab 7,5-8 kilo umbes. Muusika mahamängimine ja raadio on Ok, kuigi tabloojaotus on minu jaoks kummaline, raadio RDS-i jaoks on üks väike osa ainult või on see minu seadistuse viga. :o Võibolla peaks Pioneeri enda kõlarid paigaldama, muutub helipilt paremaks.
leits
postitati 24.12.06 10:52 Tsiteeri
Nojah eks näis, kolmapäev peaks kätte saama. Kui ei meeldi läheb müüki ning võtan midagi muud. Pikk see mikri juhe on ning kuhu paigaldasite?
Lumekass
Auto: Hetkel Auditu
postitati 24.12.06 15:05 Tsiteeri
Juhet on mikril parajalt kaasas-poolteist meetrit ikka. Kõige mõistlikum,aga ka kõige vaelvalisem on seda vedadapäikesesirmi külge. Kui vähema vaevaga, siis võib ka kellade ette panna,aga seal võib ventika undamine segama hakata ja kellade eemaldamiseks vaja jälle eest ära kakkuda
leits
postitati 24.12.06 16:02 Tsiteeri
Hmm eks tuleb proovima hakata kuhu ta kõige paremini läheb. Kuda mudu makk on ? Siuke õrnapoolne ?
leits
postitati 29.12.06 11:48 Tsiteeri
Nonii sai sisse makk aga mõned jamad:
1) Panen BT järgi telefonil ning panen maki telephone peale, ta ei leia teda üles, mingit moodi searchima ka saab panna?
2) Vana mak oli deh-5730mp, sellel subaka v2ljundit polnt. Nüüd sellel on ka 2x paari rca'sid aga yks neid on subaka v2ljund. Keiss selle, et mul orig kõllid ning filtrid vahel ning on 2 paari rcasid. vanale makile need taha lükkasin kohe kõik kõlarid töötasid, hetkel see et panen rca'd taha siis kas tuleb ainult esimestest või tagumistest. mis krt ma seal maki seadetes pean muutma?
audi97
Auto: Bmw 523i :(
postitati 29.12.06 12:08 Tsiteeri
1.) Kas telefonis on blootooth aktiveeritud? Makis paned ka otsima ja siis peaks leidma KUI SU TELEFON IKKA TOETAB BLOOTOOTHI?? Vahepeal küsib ta veel mingit koodi et saaks omavahel ühendada- mul oli vist kood 1111 (kaks päeva tagusin suvalisi nr sinna:D)
2.) Sellel makil jah on vist kaks sisendit ja üks väljundit või oli see vastupidi- ei mäleta täpselt (loe eestikeelset õpetust). Igatahes midagi peab seal tegema et saaks ühendada. Ma näiteks tahtsin panna järgi sinna läpaka. Paraku jäi asi katki, sest kui panin läppari järgi siis ei töötanud kas esimesed kõlarid, tagumised kõlarid või siis supakas. Sain lõpuks nii tööle et mängisid esimesed kõlarid ja supakas. Eniway suht keeruliseks on aetud kõik seal makil :D Kui keegi tark oskab meile nõu anda siis kuulan ise ka huviga. Mul makk olnud juba pea aasta:D Mul siis põhimõtteliselt sama makiga tegu Pioneer DEH-P70BT
Kiil
Auto: Allroad C5
postitati 29.12.06 12:55 Tsiteeri
kasutusjuhend aitab alati! ka netist saab neid.
leits
postitati 29.12.06 14:22 Tsiteeri
Nii sain enamus probleeme lahendatud ... Kõlarite jama sai sealt muudetud, et makk välja lülitada ning FUNC nuppu peal hoida, tuleb uus settingute menüü. Telefoniga saab helistada jms aga PHONE BOOKE'i ei saa transfeeritud makki.
http://files.pioneer.eu/files/eur/Car/BluetoothCompatibilityGuide.pdf
see leht väidab, et mu 6230i saab transfeerida tel raamatu makki. hhetkel keegi helistab näitab ainult numbrit :/
Panin kõik kenasti õpetuse järgi, ees oli P Book transfer vist ... ning õpetuses on edasi öeldud, et tehe oma mobiili järgi edasi vms. Ma ei osand midagi edasi teha:/
leits
postitati 29.12.06 14:30 Tsiteeri
Phonebook Transfer Procedure
Before sending phone book entries from the phone, make sure to activate the Phone Book Transfer feature on the Pioneed DEh-P55BT. With the phone source selected, long press on [func.], then press[func.] again. Push the multi controller to the right (p book transfer) and push the rotary commander up. now you can start sending your phonebook from your phone.
after activatin it, the pioneer unit will show "xxxx was disconnected" this is normal.
Manuaalist lugesin mis kaasas, et kui p book transfer on ees ja seda nuppu yles lükkan viskab ta selle satandby reziimi, mille peale telefon mul ütleb et BT yhendus katkes.
Ideid?
The Nokia 6230i, according to their compatibility list, is just about as compatible as it can be. But transfer of the 'phonebook to the Pioneer unit does not happen like the manual describes. Only after contacting support (no courtesy of a reply, just a link to pre-prepared answers that might help) did I learn that I have to transfer numbers in ONE AT A TIME, in a TEDIOUS PROCESS. Subsequently I discovered they are better transferred in alphabetical order, because the Pioneer won't sort them !
leidsin mingi sellise asja, kuid ise ei saa mõhkugi aru sellest:/
audi97
Auto: Bmw 523i :(
postitati 29.12.06 14:37 Tsiteeri
ma ise saatsin ükshaaval nimed telefonisse- ei viitsinud jamada sellega! Häälvalimine on ka üks tore asi- soovitan selle ka paika panna ;)
leits
postitati 29.12.06 15:41 Tsiteeri
Nii sain ka telefoni asja korda. Ühe kaupa saatsin tähtsamad 50 tükki ära, mis moodi see häälvalimine toimib?
edit: Nimelt üks mure on veel. Makk ei lase LOUD'i mull HI peale panna. Kas on Off või siis saan MID panna, mis põhjus võib olla?
audi97
Auto: Bmw 523i :(
postitati 29.12.06 16:57 Tsiteeri
kui sul telefonis häälvalimine toimib ja ka need nimed saatsid makki siis hoia all makil band nuppu ja räägi see nimi vaata kas helistab. Krt oli vist ikka band nupp, vist ikka oli. Proovi ja ütle, kui ei saa siis ma lähen korra oma autosse ja vaatan järgi.
Aga miks sa ei saa loud hi panna seda ma küll ei tea- minul seda problat pole. Seal makis ongi nii et kui midagi kuskil on aktiveeritud siis kaotab mingi teine asi oma aktiivsuse. Või äkki pead midagi all hoidma et see tekiks. Ühesõnaga keeruline värk:D
leits
postitati 30.12.06 18:47 Tsiteeri
Siuke küsimus audi97 sulle, äkki oskad vastada. Et ütleme, kui cd käib ning kõne tuleb võtab automaatselt vastu .. kõne ära lõppeb jääb ta telephone reziimi. Selline asi on võimalik, et kui kõne lõppeb hakkab lugu edasi automaatselt mängima?
audi97
Auto: Bmw 523i :(
postitati 30.12.06 19:02 Tsiteeri
kle minu meelest peaks ta automaatselt minema tagasi! Kui ei lähe siis pane roolipult sealt käib lihtsalt ühe klõpuga asi. Ma lähen varsti koju siis vaatan asja üle
leits
postitati 31.12.06 12:51 Tsiteeri
Hmm krt ei lähe automaatselt. Ma võtan kõne vastu jääb see kuupäev ette liht.
audi97
Auto: Bmw 523i :(
postitati 31.12.06 14:17 Tsiteeri
siis ta jääbki nii ma vaatasin et mul sama asi ma lihtsalt olen nii harjunud juba kõigega
[PHP: 12.0% - SQL: 88.0%]
