Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - 10.09.06 Tartust Haapsallu kiirendusele ühisminek
Pealkiri: 10.09.06 Tartust Haapsallu kiirendusele ühisminek (Vastuseid: 14 | Vaatamisi: 2544)
Pred
Registreerunud 17.09.03
Auto: Merida Matts HFS XC 3000
postitati 07.09.06 12:46 Tsiteeri
Kuna arvatavasti juhtub mingi ime siis plaan endal ka Haapsallu seda spektaakelit vaatama minna. Teeme siis vana hea traditsiooni kohaselt Tartust ka ühis mineku, Pärnus liitume nendega ja kihutama sealt üheskoos rõõmsalt edasi.
Koguneme pühapäeva hommikul 07.30 Lõunakeskuse parklas ja hiljemalt 07.40 stardime.
Kes tulevad ühisminekule siis andke endast siin märku :)
Kohtumiseni!
edit: muutsin kellaaegu varasemaks kuna kihutada ei soovi
Carla
Registreerunud 29.12.03
postitati 07.09.06 12:52 Tsiteeri
khm, et sõna võtan, aga miks läbi Pärnu?
Miks mitte läbi Jüri-Keila jne?
Ajaliselt peaks nobedam olema...
If you have no lag, you have no turbo. You also have no huge torque increase to look forward to.
Pred
postitati 07.09.06 13:04 Tsiteeri
Ega ajalises nobeduses polegi asi, pigem tahaks Pärnu omadega kokku saada nii nagu kunagi sai tehtud, nostalgia noh :P
Pealegi peaks Tartu-Viljandi-Pärnu marsruudil teeremont valmis olema. Ja Pärnust Haapsallu on ka loodetavasti tee valmis saanud.
Carla
postitati 07.09.06 13:10 Tsiteeri
mina siis suure eeldusega käsi...
Tõsi seekord küll mitte-audiga :(
margus
Registreerunud 15.12.02
postitati 07.09.06 13:38 Tsiteeri
Oi sõdur, sulle tuleks küll kere peale anda - niiiiii vara peab ärkama jälle ju :P Eelmine kord sai alles mingi kl 10 astuma hakatud ja siis õnneks Xan näites linnas ka õige teelõigu kätte :)
Aga mida rohkem seda uhkem ja ise püüan ka kindlalt kohal olla!
Lauri_T
Registreerunud 12.05.06
Auto: A6 1,8T
postitati 07.09.06 14:44 Tsiteeri
Pärnusse sisenedes tuleks siis arvestada Riia mnt teelõigu (Papiniidu ristist kuni Tammsaare pst ristini) remondiga. Liikluseks on antud lõik suletud. Seega kõige targem oleks Papiniidu ristmikult (Rimi juurest) keerata paremale Tallinna suunas, sealt üle silla ning peale seda vasakule. (see tee mis Vändra suunast linna tuleb) Sealt siis juba ainult otse minek, üle Tallinna mnt ritmiku ja Haapsalu poole teele. Loomulikult võib meiega liituda ka ca kella 10-ne aeg Port Arturi parklas :)
AudiTeam
ac aasta auto 2012 & 2013 võitja
Registreerunud 30.04.03
Auto: Audi S7 Sportback & Sport Quattro "Lang"
postitati 08.09.06 06:35 Tsiteeri
Teil pole und või? Üritus hakkab ju 13:00 - üle viie tunni varem hakkate sõitma?
margus
postitati 08.09.06 06:59 Tsiteeri
Paistab siiski, et asi ei ole ainult minus ehk siis - Pred neeger, tunnike hiljemaks ja sobib väga hästi :D
lorrap
Registreerunud 24.10.02
Auto: VW Passat Variant 4-motion 1,9TDI-PD
postitati 08.09.06 07:26 Tsiteeri
Heh, Tartust Pärnu kaudu Haapsallu umbes 4h.
Ning kui Pärnakatega plaanite kohtuda, siis selle peale arvestage veel 30 min. seega 4,5h täitsa normaalne.
Point see, et üksi sõites saab kiiremini, aga kui tahta kampa koos hoida, siis sõit aeglasem.
veekaheksa
Registreerunud 07.09.03
Auto: A4 TDI quattro, S8 40V
postitati 08.09.06 08:01 Tsiteeri
Üritus hakkab jah 1300, regamine 1230, jutuajamine ja tilganäppimine 1130/1100 ja ca tund aega sõiduks ja ongi olemas. Kiirustada ei ole meil kuhugi mõtet ja nagu rinka üritus näitas, jäi tilganäppimise/mula aega hullult väheks :P
lorrap
postitati 08.09.06 08:53 Tsiteeri
No täpselt, seega Margus.....
Vaat, Pred on tubli poiss, teeb teile kõigepealt Lõunakeskuse parklas 10 minutit hommikvõimlemist mille peale kolm päeva ärkvel olete nigu nalja ;)
margus
postitati 08.09.06 13:29 Tsiteeri
Kle tglt ma pigem siis püüangi end pääste Predi kiusust, mis muud ikka :P
prr
Registreerunud 20.10.02
Auto: A3 & A4 Cabrio
postitati 09.09.06 00:22 Tsiteeri
prr@co stardib kell 0900 hours Tartust. Läbi Viljandi.
lapsest peale on hobused meeldinud
Pred
postitati 09.09.06 18:19 Tsiteeri
Igatahes need kes tulevad homme varavalges, kohtume siis Lõunakeskuse parklas 07.30
Teised piripillid võivad ju ka kauem magada :)
ciao!
forsin
Registreerunud 01.07.04
postitati 09.09.06 20:21 Tsiteeri
Algselt postitas: prr
sain kaa paar tundi tagasi oma s6 -ele hääled sisse (seisis eelmisest mai kuu kiirendusest alates) ja stardin võrust ~sinuga sama aegselt võibolla kuskil teepeal juba trehvame.
[PHP: 25.2% - SQL: 74.8%]
