Pealkiri: Sigari karpa (Vastuseid: 1 | Vaatamisi: 829)
jokker
Registreerunud 10.07.05
Auto: A6 '96 ABK
postitati 02.09.06 20:23 Tsiteeri
Sigari karpa
Karpal on 1 vidin, mis pidavat 1 spetsi jutu järgi kutu olema
http://www.vagcat.com/epc/cat/au/A100/1984/5/49/72108/
http://www.vagcat.com/epc/etka/B005/030070.png
sellel joonisel detail nr. 17
idling deceleration control valve
mis selle jupi ülesanne on?
jokker
Auto: A6 '96 ABK
postitati 04.09.06 21:29 Tsiteeri
nii
midagi leidsin
An engine deceleration control system for an internal combustion engine of a vehicle is arranged to prohibit correcting an air quantity supplied to the engine when an elapsed time period from a moment of turning off of an accelerator of the engine is within a first predetermined time period, or when an elapsed time period from a moment of turning off of a lockup clutch of a torque converter is within a second predetermined time period or when a shifting of a transmission connected to the engine is being executed, and to cancel prohibiting the correction of the supplied air quantity when a braking operation is executed.
et kas vidina nö "point" on katkestada/vähendada kütuse pealeandmist gaasi lahti lastes
ehk siis kui see julla ei tööta, saab peale gaasi lahti laskmist korrask ikkagi sama alju kütet, mis ei põle ära ja kipub summutis paukuma.
olen ma asjast õigesti aru saanud?
[PHP: 17.4% - SQL: 82.6%]
