Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - mure piduritega
Pealkiri: mure piduritega (Vastuseid: 14 | Vaatamisi: 1552)
enar666
postitusõiguseta huviline
Registreerunud 28.12.04
postitati 09.07.06 18:52 Tsiteeri
mure piduritega
mure siis siuke et lampi üx päev vajus pedal põhja ja nüüd võtab pidur täitsa põhjast ja mitte erti hästi..milles võib viga olla??visuaalselt vaatasin kuskilt ei lekki nagu kah..autoks siis audi 100 c4
Simps
Registreerunud 29.01.05
Auto: erinevad
postitati 09.07.06 19:59 Tsiteeri
Ehk peasilinder, mis ei hoia piisavat survet, süsteemis võib õhk sees olla või piduripump ei tekita piisavat rõhku.
lunatic
Registreerunud 20.02.05
Auto: A4 allroad ja Volvo C70
postitati 09.07.06 20:00 Tsiteeri
Mina alustaksin pidurite õhutamisest. Kui see ei aita, on tõsisem jama (mõni voolik või silinder lekib, halvimal juhul peasilindris midagi valesti).
enar666
postitati 09.07.06 20:12 Tsiteeri
ise kahtlustan kah peasilindrit miski pärast...õhutan nad homme ära eks siiis vaatan mis saab kas vajub uuesti põhja..ja kuidas ma kontrollin seda peasilindrit?
ultra2005
Registreerunud 16.05.06
postitati 09.07.06 21:03 Tsiteeri
Kui arvestada minu kogemusi Opel Vectraga millel vahetasin piduri peapumba ära siis diagnoos selline. Vajutasid vaikselt pidurit ... vajus lupsti põhja ja võttis suht nõrgalt ... aga kui andisd järsu löögi piduripedaalile siis võttis. See on üks katsemeetod minu poolt. Kui tõesti järsult piduripedaali lüües võtab siis tasub sul tõenäoliselt uue peapumba järgi minna. Kui ABS-i peal pole on asi sinu jaoks tiba odavam. :)
XZN M16
enar666
postitati 09.07.06 21:17 Tsiteeri
abs on
ultra2005
postitati 10.07.06 08:13 Tsiteeri
Lihtsalt see et abs-i süsteemiga kokku sobiv pump on tsipa kallim. Aga katsetasid seda äkklööki v ? Hmm pumba vahetus iseenesest pole midagi keerulist. Lihtsalt keegi peab abis olema kes hiljem õhutada aitab. Aga täiesti kodustes tingimustes ära tehtav töö :)
XZN M16
enar666
postitati 10.07.06 15:44 Tsiteeri
jah katsetasin ja siis nagu parem..homme jõuab pump rapla siiis vahetan ää ja annnan teada mis muutus..
enar666
postitati 10.07.06 15:45 Tsiteeri
enar666
postitati 11.07.06 13:44 Tsiteeri
nüüdseks vahetatud piduri peapump ja piduriõli...ilmselt tuleb vahetada ka absi pump kuna keegi tark pea oli valanud piduri süsteemi automaat käigukasti õli..samas naljakas aga kulukas...pedaal tuli küll ülesse ja enam alla ei vaju aga pidurid pole ikka need mis peaks sellle auto juures olema..arvan et sellest on tingitud ka komuutril kollane kiri bremsen light..
ultra2005
postitati 12.07.06 01:36 Tsiteeri
Nu jah ... ise valalsin just hiljuti sellist toredat õli omale käimakasti :) Aga kõva asjapulk oli see küll kes seda ABS-iga pidurisüsteemi valas. Sinna käib ikka DOT.5 sisse ja asi mutt :)
XZN M16
enar666
postitati 12.07.06 10:20 Tsiteeri
ma ei taha kedagi solvata aga see oli naiste mõistus umbes 1a tagasi...
ultra2005
postitati 12.07.06 10:55 Tsiteeri
Käimakasti õli võib kasutada ka roolivõimu õlina minuteada aga see on ka kõik :)
XZN M16
enar666
postitati 12.07.06 18:51 Tsiteeri
vat seda ma ei tea..aga tundub et absi pumba pean kah ära vahetama...
jann20
Registreerunud 29.05.06
Auto: Audi A4
postitati 14.07.06 11:06 Tsiteeri
Algselt postitas: ultra2005
kapotti all on kirjas mis õli läheb, kui on abs see ei tähenda et kohe läheb dot5.
[PHP: 49.3% - SQL: 50.7%]
