Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - K: Roolivõimendi õli temperatuur?
Pealkiri: K: Roolivõimendi õli temperatuur? (Vastuseid: 7 | Vaatamisi: 1553)
mulk
Registreerunud 11.11.03
postitati 06.07.06 18:56 Tsiteeri
Sooviks teada audi "rohelise" roolivõimu õli töötemperatuuri, mis on ta normaalne temperatuur, mis miinimum ja mis maksimum.
Auto: 6x4x4
postitati 06.07.06 23:31 Tsiteeri
alternatiivne link
Asi tahab ainult peaaegu igaaastast vahetust. Kui uus sees siis on jälle hea.
ulith
Registreerunud 19.03.06
Auto: 80 b4 1.9tdi 94a/ VW G4
postitati 07.07.06 08:21 Tsiteeri
ei tahtnud uut teemat teha, ehk oskab keegi öelda , kas punast atf õli tohib ka panna audile roolivõimu, mul eelmisest omanikust on jäänud , ja kas see võib tekitada mingisugust ininat rooli keerates ????????
jõuvanker
Registreerunud 21.03.03
postitati 07.07.06 08:56 Tsiteeri
Algselt postitas: ulith
Ei tohi kasutada punast õli, ainult roheline mineraalõli G002000
Auto: 6x4x4
postitati 07.07.06 08:58 Tsiteeri
Vanemates isendites kasutaski Audi ATFi. Inin võib tulla vanast õlist, või väsivast pumbast. Roheline hydraulik õli (mineraal) pole lihtsalt nii sööbiv kui ATF, aga väsib rutem ära ja tahab kiiremini vahetust saada.
genekas
Registreerunud 30.01.03
Auto: järgmist plaanimas
postitati 07.07.06 10:35 Tsiteeri
http://www.candokaraoke.com/tony.html
Siit lehelt leiab muuhulgas ka tabeli, kus on kõrvuti toodud ka LHM+ ja Pentosin CHF7.1/CHF11 õlide põhilised tehnilised näitajad - ja nagu näeme, on heed päris sarnased (LHM viskoossusindeks on isegi parem).
Samas tabelis on kõrval ka ATF oma parameetritega.
Tegelikult on nii, et lühiajaline kasutamine häda ei tee, aga pikema aja jooksul (siis rohkem kui mõni kuu) rikub ATF oma viletsate määrimisomadustega nii mõnegi osa.
Algsele küsimusele vastates - tollelt lehelt igatahes näeb, et LHM+ keemispunkt on +255°C ja leekpunkt +135°C.
P.S. Pentosin CHF-11 peaks olema seesama asi, mida Audi müüs G002000 tähise all (nüüdseks on selle õli tähis mingi G004xxx)
genekas
postitati 07.07.06 10:43 Tsiteeri
Algselt postitas: kps
alternatiivne link
Miks seda peaks iga aasta vahetama?
mulk
postitati 07.07.06 13:33 Tsiteeri
Põhjus, miks ma seda küsin, on nimelt järgmine. Sai soetatud uus jahutusradikas, millel on autkasti õlijahutus sektsioon sees, ruumi "tekitamiseks" stange ja radika vahele, tahan roolivõimendi õli jahutamise mujale viia.
Aga kas jahutusvee temperatuur ca90C' roolivõimu õlile korgeks ei jää?
[PHP: 0.2% - SQL: 99.8%]
