Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890 Eesti Audi Klubi foorum - sigari pidurihädad
Registreerunud 26.09.05
Auto: Ex steroididel Sigar
postitati 15.06.06 19:58
sigari pidurihädad
niisiis on mu 89 aasta audi 100 avandil viimasel ajal lälle komme pidurid peale jätta ja seda eriti linnasõidul
remondis on käinud korduvalt aga asi paremaks pole muutunud
kas keegi teab milles võiks viga olla seest see on väga tüütav kogu aeg piduritega jamada.
HannesT
Registreerunud 21.01.06
Auto: B4 Avant
postitati 15.06.06 20:16
Mul oli ka kunagi 85a sigar. Muidu oli ok aga arniirid ja pidurid jamasid koguaeg. Pidurid jäid ka peale, nagu Sul. Sai mitu korda esisupporteid
vahetatud, aga ikka. Lõpuks aitas piduri peapumba lahti võtmine ja kolvi ja silindri seest ära puhastamine(liccalt pidurivedeliku vahetamisest polnud
ka abi, sest see ei puhasta piisavalt.). Aga jah mingi imelik system pidi sigasil olema, et roolivõim ja pidurivõim ühes-tükis ja uuena 10kkr vm.
Audiamus
Registreerunud 04.01.05
postitati 15.06.06 21:32
mul oli ja on ka 88 a sigar, aga sellel kõik korras. A sisi tuleb sul
supporteid vahetada või korda teha kui need kinni jäävad. Mul tehti ja siiani...
Zandr
postitati 16.06.06 20:16
mul vahetati nuud pool piduri süsteemi ka ära aga pärast seda läx hullemax
vahepeal oli isegi täica norm juba, aga nüüd jälle
kõike on ka põhjalikult lastud puhastada aga see ei mõju kaua- paar nädalat ja jälle
[PHP: 49.1% - SQL: 50.9%]
