Pealkiri: Anduri kood? (Vastuseid: 1 | Vaatamisi: 1548)
Kirsa
Registreerunud 20.05.04
Auto: Audi Coupe Q 20v
postitati 15.06.06 13:34 Tsiteeri
Anduri kood?
Mis võiks olla selle anduri kood?
Jutt allpool:
Reference Sensor G4
The reference sensor is an inductive pickup. The sensor is located on the left-hand side of the engine block. The sensor is used to identify TDC of the number three cylinder.
A notch, 62° before TDC in the counterweight of the crankshaft for the number three cylinder, is used as the reference point. The notch, along with the reference sensor, generates one signal per crankshaft revolution.
The signal from the reference sensor along with the signal from the Hall Sensor (G40) are used during starting to identify the TDC third cylinder ignition point.
Teise nimega:
00514-Ignition Point sensor
Kaits
Registreerunud 01.03.03
Auto: RS 6 Avant
postitati 15.06.06 14:10 Tsiteeri
Peaks olema 034 905 381. Det. nr. 2 sellel pildil:
http://www.elcats.ru/audi/parts.asp?mdl=089&unit=5EB0460A
See andur "loeb" hoorattal oleva pulga pöörlemist.
"Reference Mark Sensor (G4) and Engine Speed Sensors (G28)
The two sensors are identical in design and are located on the left side of the engine compartment, near the flywheel.
The reference sensor is used by the ECU to identify the crankshaft position. A steel pin is pressed into the flywheel 62° before Top Dead Center (TDC) for the #1 cylinder. The pin, along with the sensor, generate one signal per crankshaft revolution.
The speed sensor produces an alternating current (AC) voltage signal by scanning the teeth of the flywheel. This signal is used by the control unit to measure engine speed.
If either of the sensors fail, the engine cannot be started. However, if the reference sensor fails when the engine is running, the system will use the #1 cylinder signal that was used when the engine was started. "
[PHP: 22.1% - SQL: 77.9%]
