Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - A4 1.8 T "pressure regulating valve"
Pealkiri: A4 1.8 T "pressure regulating valve" (Vastuseid: 9 | Vaatamisi: 1561)
piltnik
Registreerunud 26.04.05
Auto: A4 1.8TQ
postitati 13.06.06 08:21 Tsiteeri
pressure regulating valve (nr.20)
joonis:
http://www.sarlog.ee/audi/klapp.pdf
kes vastab millega see klapp tegeleb ja kuidas teada saan et, ta on töökorras ?
Tänan.
xjan
Registreerunud 25.11.02
Auto: Audi Q7 4,2TDI, VW Passat 1.8T, BMW 323ti
postitati 13.06.06 12:46 Tsiteeri
Ülerõhuklapp - gaasiklapi sulgumisel ventileerib liigse rõhu tagasi õhuvõtusüsteemi säästes nii turbot - ei poo kinni käiguvahetustel nõnda palju ja ei "vääna" võlli.
Enamasti on need defektsed - ehk lekivad valel ajal rõhku, eriti kui on nad vanemad kui paar aastat ja veelgi enam kui masin chipitud.
Eluagne selline performance-klapp, Forge Motorspordilt ja metallist ning puhastatav jnejne maksab 2415 eek letis. Meil enamasti need ka laos olemas ;)
http://www.forgemotorsport.co.uk/images/products/FMCL007P.jpg
andero
Registreerunud 03.09.03
Auto: audi a6 3.0 TDI Quattro
postitati 13.06.06 13:40 Tsiteeri
Kas mitte Xjani poolt pakutav klapp ei ole nn. by-pass(joonisel nr 14)?
Ise olen samamoodi vaadanud seda nr. 20 klappi ja mõelnud mis ta teeb ja kuidas tema korrasolekut testida.
Silwer
Registreerunud 11.12.02
postitati 13.06.06 13:49 Tsiteeri
Algselt postitas: andero
Jep, Xjan räägib joonisel nr. 14 olevast klapist. Ja see ongi tavaliselt see mis töökorrast ära läheb. Klapp nr. 20 on seotud karterituulutusega.
BMW 325i E30 2,8 stroker & BMW 328iT E36 & Seat Altea XL 2,0 TDI+DSG
forsin
Registreerunud 01.07.04
postitati 13.06.06 13:59 Tsiteeri
Algselt postitas: Silwer
Jah se pole BY bass.
nr 20 karteri surve tagasi laskja ja lõpetab tuulutus torustiku enne turbot imu alas, seal pole vahet kas se klapp töötab või ei peamine et ta midagi läbi laseb.
Probleem teki siis kui selle klapi tagalt katki siis imeb lisa õhku (lugemata õhku)
piltnik
Auto: A4 1.8TQ
postitati 14.06.06 08:40 Tsiteeri
üks ots jookseb jah karterisse. otsast sisse vaadates paistis ka mingi vedru. igatahes öhk jookseb sealt vabalt läbi mölemat pidi. või on selle klapi mure pidurdada öli sattumist karterist öhusüsteemi, ei tea.
mulk
Registreerunud 11.11.03
postitati 14.06.06 17:15 Tsiteeri
Kui tegemist on analoogse karterituulutus klapiga, nagu 2.2 20VT´l on, siis minu mälu järgi ei tohiks see klapp lekkida igast asendist. Nimelt, kui tekib sisselaskesse ülerõhk, peaks see klapp olema suletud, "vaakumialas" aga toimub selle kaudu karteri ventileerimine.
läheb tiba ot´le, kuid, survestustest toob selgust sellistele tüüpilistele probleemidele.
piltnik
Auto: A4 1.8TQ
postitati 15.06.06 06:34 Tsiteeri
kuidas siis olla kindel et see klapp ikka oma kohust öigesti täidab. Kas on targem ikkagi uus osta.
andero
postitati 15.06.06 08:02 Tsiteeri
Samas ei tohiks sisselaskes tekkiva rõhuga sellel klapil mingit pistmist olla. Asub ta filtrikopsikust turbosse mineva toru küljes. Seal ju rõhku ei teki?
piltnik
Auto: A4 1.8TQ
postitati 17.06.06 19:58 Tsiteeri
vahetan ära !
[PHP: 50.5% - SQL: 49.5%]
