Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890 Eesti Audi Klubi foorum - K: õli võtab?
Algselt postitas: kurimurijan
mul võtab auto õli kusagil 1000 km/1l
kas see on normaalne
ja kui ma koguaeg õli peale panen,kas ma siis ei peagi õli vahetama?
ja kas peab kogu aeg ühte ja sama õli panema?
Ära solvu palun kurimurijan, kuid juba teist sinu teemat lugedes tekib tahtmatu küsimus, et on see avataris märgitud ikka sinu auto v. oled veel
lubadeks liig noor ja küsid isa eest?
TiitR2
Registreerunud 21.07.04
ma arvan et olen vanem kui20
Kas arvad v. tead?
HannesT
Registreerunud 21.01.06
Auto: B4 Avant
postitati 07.06.06 16:42
ah mis sa ikka norid ja üldse: mis näitaja see 20a on? oleks, et 21a veel, vot siis ma saan aru....ma ise ka 21a ja.....
riio
Registreerunud 22.01.06
postitati 07.06.06 17:08
Mis te norite siin...ehmatasite teise ära....Mõtetus on nii jamada üksteise kallal.
Loomulikult pead õli vahetama ja soovitavalt ka läbi peasta kes teab kui palju seal saasta ja sodi on suurte peale valamistega sattunud-.
[PHP: 48.3% - SQL: 51.7%]
