Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Auto tagavedrustus hakkas kägisema!?
Pealkiri: Auto tagavedrustus hakkas kägisema!? (Vastuseid: 2 | Vaatamisi: 1081)
saxy
postitati 24.05.06 18:31 Tsiteeri
Ühel päeval hakkas tagavedrustuse juures täiesti äkitsi käuksuma, no nii totaalselt. et lausa hirm hakkas. Ja seda nii äkki ja linnaliikluses, et ei oska midagi tarka arvata. Isegi tühiseimad ebatasasused kräunuvad, nii et kriibib kõrva. Tean isegi, et peaks siis puksivahetusele mõtlema hakkama, ent ... kuidas ikkagi nii hetkega see juhtus??? PS. Auto A6 Q aastast 95.
Ingvar
Registreerunud 11.05.04
postitati 25.05.06 05:09 Tsiteeri
Arvatavasti kääksuvad sul tagumise reguleerimisvardad.
arvoest
Registreerunud 30.09.03
Auto: Subaru Impreza WRX
postitati 25.05.06 05:16 Tsiteeri
äkki vedru katki,
omal läks tagumine ja näha oli, et üks auto pool teisest sent või paar madalam, muu järgi aru ei saanud
[PHP: 47.5% - SQL: 52.5%]
