Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - 2,3e mootoril viimane silinder ei tööta
Pealkiri: 2,3e mootoril viimane silinder ei tööta (Vastuseid: 9 | Vaatamisi: 1458)
aabu
Registreerunud 20.05.06
postitati 21.05.06 15:00 Tsiteeri
külma mootoriga alul kõik pütad tõõtavad,hiljem kaob viies ära.sõidu ajal jälle kõik tõõs.viies küünal märg.kas viga pritsungipeas?kus tartus tasuks remontida?
warp25
Registreerunud 16.06.04
Auto: Audi 200T typ43 80a
postitati 21.05.06 18:10 Tsiteeri
Pritsepeas viga ei saa olla.Tõmba viienda püti pihusti välja ja käivita mootor(peaks ka nelja pütiga käima minema).Vaata kuidas pihusti töötab.Proovi nii külma kui ka sooja mootoriga.Igaks juhuks mõõda ka surved silindrites ära.
genka1975
Registreerunud 31.01.06
Auto: 2,3 100 C4 91 a. 98 kw man.
postitati 22.05.06 11:41 Tsiteeri
Ja endal ka sama moto. Aga viga ilmneb selles, et tühikäigul ja tuuritades on kuulda sumpast õrnad paugud.
Mul kästi diagnossis ka pihusteid vaadata. Et kas sisselaske kolde eemaldamine on suur töö? Ja mingid plastikust puksid pidid ka õrnad olema.
Alustusekt soovitati STP pihustipuhastajat bensu sisse panna. Ei tea, kas ka aitab. Kaks päeva a-la 100 km olen sõitnud selle seguga, vahet pole.
Räägi tõtt, või vahemalt ära valeta.
TurboQuattro
Registreerunud 15.05.04
Auto: Audi 80 Avant Q ´94, Audi Coupe 2.0 ´91, Audi Coupe 2.6 `93, Ford Sierra P100, Volvo V70R
postitati 22.05.06 11:51 Tsiteeri
kui küünal märg siis proovi ikka alul küünal vahetada, kasvõi tõsta muu silindri peale ringi ja vaata mis siis teeb.
pihustipuhastusmöga minul küll ei aidanud, ei muutunud mitte midagi, seda pead pikalt kasutama ja mitu paagitäit ära sõitma, enne kui midagi mõikama hakkab.
jõuvanker
Registreerunud 21.03.03
postitati 22.05.06 13:32 Tsiteeri
Kontrolli pihusti ja küünal viiendas silindris, mõõda surve. Suure tõenäosusega pihusti väsinud. Ära kasuta mittemingisuguseid pesuvahendeid/bensiinilisandeid!
genka1975
postitati 22.05.06 14:21 Tsiteeri
Miks mitte kasutada? Seda tean diisliauto omaniku ajast, et viga tehakse nii, et kallatakse aine paaki ja siis sõidetakse lühikesi otsi. Aga sodi tuleks välja pest järjest, sest vastasel juhul paakub see lihtsalt uude kohta ja asi võib tegelikult hullemaks minna.
Seega on soovitav teha just pikki otsi. Sest näiteks Xsado soovitab sama, muidu katkeb kasulik protsess.
genekas
Registreerunud 30.01.03
Auto: järgmist plaanimas
postitati 22.05.06 19:33 Tsiteeri
Algselt postitas: jõuvanker
Mehaanilise pritse pihustid on keemiaga lihtne täiesti kõlbmatuks muuta...
epic
Registreerunud 26.05.05
postitati 22.05.06 19:59 Tsiteeri
Jah, sest meh pritsel on viimane asi kütusetorustikus pihusti. Kõik saast sadestub sinna ja ongi.
Pihusteid saad puhastada - lased kompressoriga õhku sisse, siis ta avaneb. Kui on avanenud, tuleb miskit vahele ajada, et ta ka lahti jääks. Ja siis vastassuunas läbi puhuda. Pritsepeas on pihustite torude aukudes sõelad - ka need on tihtipeale umbes, mul endal oli vana autoga sama jama ja töötas teine ainult tühikäigul.
genekas
postitati 23.05.06 20:15 Tsiteeri
midagi sinna vahele ajades on oht pihustiots tuksi keerata
genka1975
postitati 23.05.06 22:24 Tsiteeri
Kas eraldi 2,3 motole pihusti otsi pole?
Või see rohkem diisli meeste maailm?
[PHP: 43.1% - SQL: 56.9%]
