Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Deprecated: Implicit conversion from float 260728.00000000003 to int loses precision in /data01/virt4271/domeenid/www.audiclub.ee/foorum/viewthread.php on line 181
Eesti Audi Klubi foorum - Jahutussüsteemist väiksema radiaatori eemaldamine
Pealkiri: Jahutussüsteemist väiksema radiaatori eemaldamine (Vastuseid: 6 | Vaatamisi: 1319)
ivar80
Registreerunud 22.11.05
postitati 08.05.06 19:48 Tsiteeri
Tegemist siis Audi 90 ja 2,3l 100kw mootoriga. Olen vaadanud, et sellel väiksemal jahutusradiaatoril, mis seal süsteemis on pikka eluiga enam pole ja hakkab varem või hiljem tilkuma kindlasti. Siit siis küsimus, et kui see sealt üldse ära jätta, siis kas teine radiaator saab Eestimaa "kuumas" suves üksinda jahutamisega hakkama?
Graabel
Registreerunud 25.09.02
postitati 09.05.06 10:29 Tsiteeri
Kui sul on suurel radikal ees kondiradikas siis vist kisub jamax. Kui aga kondiradikas eest ära võetud siis ei tohix probleemi olla. Kui väikse ära võtad siis peax ka suure radika ära vahetama kuna vanal ju väikse jaox eraldi väljundid. Ei mäleta peast kuidas need torud olid aga arvan, et neid lihtsalt kinni panna ei ole väga hea. See on vähemalt minu arvamus.
ivar80
postitati 09.05.06 10:33 Tsiteeri
ma ise arvasin, et need lõdvikuotsad paneks kokku omavahel, mis üle jäävad. peaks ju tsirkuleerima edasi küll niiviisi. konditsioneeri radikas on jah hetkel kyljest ära kuna ka lõhki. uus maksab aga paraku nii palju et seda sinna küll kunagi enam ostma ei hakka.
äss
ac aasta auto 2011 võitja
Registreerunud 23.03.04
Auto: 2x 1,8t ja masuudipress
postitati 09.05.06 15:29 Tsiteeri
ma omal viskasin ka selle väikese radika suure kaarega minema :D ... siiamaani pole veel liiga kuumaks läinud ja mul on veel kondi radikas ka ees. Väikesesse radikasse minevad lõdvikud ühendasin omavahel torujupiga.
ivar80
postitati 10.05.06 08:04 Tsiteeri
seda ma arvasin et keegi on sellise variandi ikka ära katsetanud :D
tänan et viitsisite vastata :)
äss
postitati 10.05.06 16:33 Tsiteeri
Radikas muidu maksab 3800.- B grupina kui kedagi peaks huvitama :D
genekas
Registreerunud 30.01.03
Auto: järgmist plaanimas
postitati 10.05.06 20:39 Tsiteeri
Algselt postitas: ivar80
need vabad otsat tuleks kinni panna - nende kokkuühendamisel hakkab jahutusvedelik lihtsalt suurest radikast mööda ringlema, mis vähendab jahutuse efektiivsust veelgi.
[PHP: 48.1% - SQL: 51.9%]
