Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - bensu rõhuregulaatorist
Pealkiri: bensu rõhuregulaatorist (Vastuseid: 0 | Vaatamisi: 979)
tann83
Registreerunud 16.12.05
Auto: coupe 90a
postitati 03.05.06 13:16 Tsiteeri
Autol on pöörded kõrged ja regulaatori vahelt ajab veits bensu välja.tõmbasin täna selle regulaatori küljest pistiku ära,siis läksid nagu pöörded korda.Aga nii kui veits temp. tõuseb läheb ikka käest ära (pöörded), aga parem kui ennem.Kas see midagi muudab ka kui pistik küljest ära on? Kas kellegil on seda regulaatorit müüa,sest käisin aaves küsimas seal hinnaks ütlesid 3500.-,ning kas seda ise näppida tasub või peab seal midagi täpselt regullima.Autoks siis a80 1.8q 83kw.Regulaatori tootekood on 2437020005/742 bosch. Sorry kui jutt veits segane ja pikk!!!!
[PHP: 47.7% - SQL: 52.3%]
