Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - K:Pidurite kohta
Pealkiri: K:Pidurite kohta (Vastuseid: 15 | Vaatamisi: 1353)
Sniper
Registreerunud 26.09.04
postitati 29.03.06 11:48 Tsiteeri
K:Pidurite kohta
Kuna otsingud tulemust ei andnud (võibolla otsisin valest vms.), siis küsimus selline.
Vahetasin eile esimesed piduri klotsid, kettad ja puhastasin ära suporti koos kolviga.Suportit koos klotsidega tagasi pannes läks kogu krempel suht tihkelt peale ja nüüd kui täna hommikul linna tööle sõitsin, siis esimese foori taga tunnen, et salongi tuleb piduri kärsakat.Jõudsin tööle ja kettad olid täiesti tulikuumad ja õrnalt sinakad.
Kas see on uute klotside ja ketta puhul normaalne nähtus, et klotsid vastu käivad?
jan-kos
Registreerunud 23.04.03
postitati 29.03.06 12:19 Tsiteeri
Ei ole normaalne nähtus.
syo
Registreerunud 03.04.03
Auto: Audi A6 3,0 Q 2006
postitati 29.03.06 12:30 Tsiteeri
Algselt postitas: Sniper
äkki jäi kolb liiga välja ja ei jõua ennast tagasi sisse keerata?
kuusk623
Registreerunud 02.11.03
Auto: Audi 100 C4 avant
postitati 29.03.06 12:32 Tsiteeri
Ma arvan, et on kyll normaalne, kui sa ennem neid sisse ei sõitnud. Kui ketta pind päris sile pole, siis alguses klots ei puutu terve pinnaga vastu ketast. Natuke aeg pidurdad ja siis kui klots kulub ketta järgi ära ja hakkab terve pinnaga pidurdama, siis kaob kärsakas ka ära. Sest siis ei lähe ju nii tuliseks. Kogu pidurdus nõuab vähem klotsikasutust ja ei lähe kärssama ....
Nu see mu oma kogemus ... aga kuld ei pruugi see olla. otsusta ise kas usud või mitte ;)
Kui ma ise klotsi vahetan siis ikka teen kohe paar ringi ka ja jahutan kettaid ja pidurdan jälle, et klotsi sisse töötaks, ennem kui liiklusesse ronin.
Edu ...
Sniper
postitati 29.03.06 12:52 Tsiteeri
Kolb ei saa silindrist liiga väljas olla sest tegu on uute klotside ja kettaga.Samuti ei ole seal ketta järgi midagi sisse sõita, kuna ketas on täiesti sile.
jan-kos
postitati 29.03.06 13:11 Tsiteeri
Kui asjad on uued ja läks tihkelt peale (kolb ikka silindri põhjas ilusti) siis soovitaks et lase klotsid liivapaberil natuke õhemaks, et ilusti vabalt jooksma hakkab.
ranz
Registreerunud 29.09.02
postitati 29.03.06 13:12 Tsiteeri
Vabalt oleks vaja ratas käima saada igatpidi, olgu asi milles tahes... muul juhul on need kettad suht kiirelt kõverad.
Simps
Registreerunud 29.01.05
Auto: erinevad
postitati 29.03.06 13:48 Tsiteeri
Veel üks võimalus on, et kettad on liiga paksud ning neid tuleb õhemaks treida. Mis kettad sa ostsid ?
Sniper
postitati 29.03.06 14:08 Tsiteeri
Algselt postitas: Simps
Metelli jahutusega kettad 288x24,9
Simps
Auto: erinevad
postitati 29.03.06 14:14 Tsiteeri
Kui need kettad su autole mõeldud on, siis ei tohiks selles probleem olla, lihtsalt mu sõbral oli paar nädalat selline kogemus, et autopoes soovitati civic-ule muu automudeli kettaid, et need odavamad ja peaksid ka sobima, aga need olid liiga paksud. Hiljem keelduti kettaid tagasi võtmast ning ta pidi need õhemaks treima.
Sniper
postitati 29.03.06 14:17 Tsiteeri
Need ikka sellele autole mõeldud kettad.
kaljukoll
Registreerunud 26.04.03
Auto: Audi 100 Avant 2,5 TDi;Kawasaki kvf 4x4
postitati 29.03.06 14:49 Tsiteeri
ei tea kuidas bensukal on aga dislal oli ka selline jama kord et ketas oli ettenähtud paksusega (19mm) kuid kui võrdlesime näiteks odavaid klotse enamvähem korralike klotsidega siis paksuse vahe erines jah pea 2mm , asi siis selles et odaval klotsil oli klotsi metallosa paksu värvi all ja ei tahtnud kuidagi puhastatud suporti pealgi korralikult liikuda, ravisime siis tiba neid klotse ja hakkasid käima küll;)
Mülkad mulle meeldivad raisk ....
Audiamus
Registreerunud 04.01.05
postitati 29.03.06 15:03 Tsiteeri
soovitan uuesti lahti võtta üks ratas ja uurida... mis värk on... lähemalt
tamm112
Registreerunud 14.03.04
Auto: vis 2345
postitati 29.03.06 15:18 Tsiteeri
olen kindel, et sa ei keeranud kolvi lõpuni sisse. Et seda teha, tuleb sul hankida hea haardega tangid ja keerata lahti ainult üks polt (liugtapp).
must_ratsu
Registreerunud 04.09.05
Auto: quattro coupe
postitati 29.03.06 15:28 Tsiteeri
kui sa ostsid omale odavamad klotsid siis on asi selge...kuna ma ostsin oma eelmisele autole ka odavamad klotsid ja siis olin ka pinges et mis kärsakas....sain teada eistrimehelt et oli myydud mingid tugevamast materjalist tehtud klotsid ,mis kuluvad vähem ja seega piinavad ketast rohkem...ei saanud muud kui ostsin kettad ja klotsid uued....maksin kyll rohkem aga vahe oli kohe märgatav.....ah jaaa ja see krigin ja vilin mis oli eelnevate klotsidega oli ka jube,algul vaikne kuid nac hiljem suurem heli,kuni siis jõudiski kätte see terve kupatuse vahetus....muidugi ma ei garanteeri et sul sama jama...aga loodan on abi....
don't smoke drug's,smoke tire's!!!!
jan-kos
postitati 30.03.06 06:18 Tsiteeri
Ma ei saa aru, mis asja te keerate esimestel piduri sadulatel, need kolvid peaks minema lihtsalt sisse pressides.Või on olemas ka keeratavaid nagu tagumised?
[PHP: 48.5% - SQL: 51.5%]
