Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - K:Tõmbas täis? CO LAES???? ASI KORRAS!!!!!!!!!
Pealkiri: K:Tõmbas täis? CO LAES???? ASI KORRAS!!!!!!!!! (Vastuseid: 22 | Vaatamisi: 2604)
syo
Registreerunud 03.04.03
Auto: Audi A6 3,0 Q 2006
postitati 15.03.06 17:57 Tsiteeri
Nimelt siis täna oli see päev kui sai klapisääre tihendid vahetatud. vahetus käis siis nii et küünlaaugust surve sisse jne.. lahti sai võetud ka veel bensiini torud. pärast kõik koos uus õli ka sees, splundrid said õiges järjekorras tagasi pandud ja auto käima ei lähe...??? küünlad maha ja kõik bensiini täis. lasime siis tühjalt käija bensiini välja ja lõpuks pika käijamise peale läks käime suitses turtsus ja lõpuks kõik nagu ok. co ei saanud veel ära kontrollida.
Mis me valesti tegime miks ta täis tõmbas?
samru
Registreerunud 01.02.04
postitati 15.03.06 18:50 Tsiteeri
Enne kokkupanemist tuleb hüdrotõukurid õlist tühjaks pigistada, sest muidu ei teki kompressiooni (klapid jäävad avatuks) ja mootor ei taha käivituda.
syo
postitati 15.03.06 19:05 Tsiteeri
Algselt postitas: samru
ja sellest ka siis see et ennast täis tõmbas?
ometi mees oli ise ka üllatunud et esimene kord kui selline jama tekkis ennegi nii teinud ja pole sellist jama veel olnud.
ja kui ta on nüüd ennast tühjaks köhinud ja ilusti käima läheb et kas ta nüüd midagi valeks ei tõmmanud co vms?
pampkuri
Registreerunud 08.03.04
postitati 15.03.06 20:09 Tsiteeri
Pudel ära peita siin ei aita miski muu. ;)
syo
postitati 16.03.06 14:36 Tsiteeri
Sai siis täna tüv le mindud ja kõik mudu ok aga co tühikäigul 6,30 ja pöörtega 5,18???????????
see ju meeltu kas asi on 100% lamdas.
Kuna meil siin pärnus ju asjalikke elektri mehi vähe tuli cateweesi aeg kinni panna 400.- selle eest et ütleb kas on pees või ei ole. kui nüüd homme öeldakse et lamda pees pole mida järgmisena vaadata?
kütte kulu on siisn ka enamvähem 10 sajale 2,0 85kw võib olla on natuke palju. moto töö temp mõõtmisel oli kliima puldi järgi 92 kraadi kas sellest ei olene et sise meh. kell näitab mööda? kas sealt kellast ei lähe inf ajusse et moto koguaeg külm?
ise kahtlustan ka lamdat sest pöörded ka jamavad alalõpmatta.
tänud kes vastasid.
syo
postitati 16.03.06 18:22 Tsiteeri
up
äss
ac aasta auto 2011 võitja
Registreerunud 23.03.04
Auto: 2x 1,8t ja masuudipress
postitati 16.03.06 18:33 Tsiteeri
Algselt postitas: syo
Mootori aju saab samast kohast info kust kliima - tegelikult kliima saab info mootori ajust :D .. seega see, mida kell armaturis näitab ei mõjuta mootori tööd.
syo
postitati 16.03.06 18:39 Tsiteeri
Algselt postitas: äss
selge tänud!
aga mis arvad kas piisab lamda vahetusest?
äss
postitati 16.03.06 18:43 Tsiteeri
selge tänud!
Kui pees on, siis ehk piisab :) ... kõigepealt uuri välja kuda lambda toimetab.
syo
postitati 16.03.06 18:46 Tsiteeri
kellegil veel arvamusi?
genekas
Registreerunud 30.01.03
Auto: järgmist plaanimas
postitati 16.03.06 22:49 Tsiteeri
Kui asi nii oleks, siis käiks mootorit ringi keerates kohe klapid kolbides ära - sellepärast on hüdrotõukurite puhul vajalik peale nukkade tagasipanekut lasta mootoril vähemalt pool tundi liikumatult seista, et tõukurid õige asendi sisse võtaks...
syo
postitati 17.03.06 06:22 Tsiteeri
Algselt postitas: generaator M
et siis kellel õigus on?
tarts
Registreerunud 25.09.02
postitati 17.03.06 07:18 Tsiteeri
paistab, et Samru ja ilmselt siis ka Rain Aava teevad nii, ka mina olen alati tõukurid tühjaks teinud ja mina olen aastaid tagasi alustanud mehe õpetussõnade järgi, kellel on mootorite tegemises mitmekümne aastased kogemused ja pole raske arvata, et ka tema teeb tõukurid enne tühjaks.
Samas tean, et tehakse ka teisiti, äkki siin ongi see 30min küsimus?
syo
postitati 17.03.06 20:15 Tsiteeri
Algselt postitas: tarts
võib olla tõesti.
syo
postitati 17.03.06 20:18 Tsiteeri
TEEMA LUKKU!!!
CO OLI LAES SIIS hoopis mitte lambda vaid temp anduri pärast mia andis valet inffi ajule!!
http://www.zone.ee/syo666/1.jpg
pildil andur nr 1.
Ja mehed julgelt pärnus võite diagnost minna cateweesi minul arvamus muutus peale tänast käiku.
Ülevaatus tehtud ja läbitud puhtalt!!! JA NB!!!! Sellest kadus ka see pöörete jama mis mul oli et käisid ülesse alla!!
Tänud kes aitasid!
ZharpV6
Registreerunud 27.12.05
Auto: Audi 80 B4 Avant 2,6
postitati 18.03.06 20:20 Tsiteeri
Palju Catwees's diagnostika maksma läks? Peaks ka ehk läbi käima, mootori hääl tundub kuidagi "rabe".
janar
Registreerunud 16.11.03
Auto: A6 Avant
postitati 19.03.06 07:23 Tsiteeri
kas see nr 1 on see sinine andur ? Minu teada peaks see olema külmkäivituspihusti andur.
samru
postitati 19.03.06 07:43 Tsiteeri
Klapid kolbidesse ei lähe, sest nad jäävad avatuks väga vähesel määral. See pooletunni jutt on samuti õige, kuigi tihti sellest poolest tunnist jääb väheks. Kuna teeninduses on aeg kallis, siis meie teeme tõukurid õlist tühjaks, saab lihtsalt kiiremini ja 100% kindlusega asja tööle.
syo
postitati 19.03.06 09:56 Tsiteeri
selge siis järgmine kord tean.
Tänud igatahes.
syo
postitati 19.03.06 09:57 Tsiteeri
Algselt postitas: ZharpV6
diagnosti tund oli seal 400.- mul läks ainult pool tunnikest.
genekas
postitati 19.03.06 12:26 Tsiteeri
Kui tõukurid on uued, siis nad ongi algselt tühjad.. :D
Tegelikult see poole-tunni-teema jäi omal ajal Haynes'i manuaalist silma just sellesamä täpsustusega...
postitati 19.03.06 12:43 Tsiteeri
K:Tõmbas täis? CO LAES???? TEEMA LUKKU!!!
Kas on tõesti nii raske selle "LUKKU!!!" asemel kirjutada "lahendatud" või midagi sellist. Või tahad meelega provotseerida? Ütle üks põhjus, miks me peaks selle teema reaalselt lukku panema?
syo
postitati 20.03.06 20:17 Tsiteeri
Algselt postitas: Black
parandatud!
[PHP: 57.7% - SQL: 42.3%]
