Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - A4 TDI automaatkast toodab vibrat, milles asi?
Pealkiri: A4 TDI automaatkast toodab vibrat, milles asi? (Vastuseid: 2 | Vaatamisi: 1215)
pisike99
Registreerunud 15.12.05
Auto: Audi A4
postitati 08.03.06 06:46 Tsiteeri
Hankinsin naisele 96a 81kw TDI A4 autom. Maanteekiirusel u.90 tekkib õrnalt gaasi juurde andes aeg-ajalt sekundi-paari pikkune vibra, mis tundub tulevat kasti ebaõnnestunud soovist kas turbiin lukustada vms? Tuleb meelde, et mul omal oli paar aastat tagasi ka 66KW autom. A4 ja see tegi ka niimoodi. Kas kellelgi on kogemust, milles võiks asi olla? Search andis tulemuseks veel ühe sama sümptomiga küsimuse, kahjuks ilma vastuseta.
www.usauto.ee on see, mis ma teen.
T.P.
Registreerunud 19.03.04
Auto: puudub
postitati 08.03.06 07:25 Tsiteeri
äkki mõnest siin asuvast teemast abi?
http://forums.audiworld.com/a4/msgs/2506993.phtml
http://forums.audiworld.com/a4/msgs/2382089.phtml
br,
T.
jalgratturid jalgrattateele
sokkk
Registreerunud 10.07.04
Auto: Passat 1,9td ´99
postitati 22.03.06 18:17 Tsiteeri
http://www.vwklubi.org/forum/viewthread.php?tid=13305
Minul läks ta 14kilo maksma:( (sokkk=hokan)
Proovin vahelduseks Passatit
[PHP: 44.6% - SQL: 55.4%]
