Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - k: C4 rehvilaiuse probleem
Pealkiri: k: C4 rehvilaiuse probleem (Vastuseid: 3 | Vaatamisi: 1257)
muster44
Registreerunud 19.02.06
Auto: audi C4
postitati 19.02.06 14:15 Tsiteeri
mure selline et C4 all praegu 215/60/15 seda laiust raske leida aga kas 225/60/15 või 225/55/15 lähevad alla ja ega naad vastu käima ei hakka, kas kellegil on 225 C4 all. Tänan vastuste eest.
muster44
Auto: audi C4
postitati 20.02.06 20:00 Tsiteeri
kas keegi ei tea siis we
Kaaku
Registreerunud 11.10.04
postitati 20.02.06 20:22 Tsiteeri
Mul on 225/50/16 (ära seda mõõtu omale võta. Ilgelt raske rehve leida) ja mahub ilusti.
Muide, reaalselt on see 225 hoopiski 240. Ära mõõdetud.
tnx
Registreerunud 03.10.05
Auto: Audi A8 Quattro
postitati 20.02.06 21:20 Tsiteeri
Mul on 235/45/17 mahub ka ilusti.
[PHP: 47.9% - SQL: 52.1%]
