Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - K: Paar küsimust?
Pealkiri: K: Paar küsimust? (Vastuseid: 5 | Vaatamisi: 1561)
zaazk
Registreerunud 09.09.04
Auto: Audi A6 C5 Avant 2,5 TDI 132kw Quattro 2004
postitati 09.02.06 21:40 Tsiteeri
K: Paar küsimust?
1.) Kas typ44/C4 armatuurkellade sihverplaadid on ühesed typ89/B3/B4 omadega, on nad ühes mõõdus?
2.) Kas coupe B4 esistange sobib coupe B3 ette 1:1?
3.) Kus asub coupe B3 2,3 NG motol jahutusvedeliku andur, mis näitab armatuuris selle vähenemisel märguande tuld?
zaazk
postitati 14.02.06 15:02 Tsiteeri
:o?
Aiku
Registreerunud 03.04.04
Auto: AUDI A6 C5 1,8T 2000a.
postitati 15.02.06 05:53 Tsiteeri
Armatuuri kellad peaksid ikka kõik ühes mõõdus olema.
Jahutusvedeliku taseme andur peaks olema paisupaagi all
postitati 15.02.06 07:30 Tsiteeri
Kus nad siis ühtemoodi on, C4 suured kellad on ju alt lõigatud servaga, B4 omad tervenisti ümarad. See peaks juba midagi lammutamata suvalisi auto24 pilte vaadates näha olema...
zaazk
postitati 15.02.06 16:22 Tsiteeri
Algselt postitas: Black
seda just teada tahtsingi, et kas see lõigatud äär jääb näha kui C4 sihvrid B4 armatuuri panna, mõtlesin et võibolla see äär jääb sinnna alla peitu, kui armatuuri korpus peale panna.
nüüd siis asi selge:D
zaazk
postitati 22.02.06 14:07 Tsiteeri
[PHP: 23.4% - SQL: 76.6%]
