Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890 Eesti Audi Klubi foorum - K:V8 õlirõngad.
Registreerunud 30.01.05
Auto: Üks teine auto
postitati 29.01.06 15:07
K:V8 õlirõngad.
Uurisin Etka`st ja ei õnnestunud leida kolvi rõngaste kohta midagi. Et ehk keegi teab kas 3.6L V8 õlirõngaid annab vahetada või ei. Surved on kõigil
silindritel 15-16bar. aga kolmas silinder ajab küünla õlisodi täis. 1000.km kohta läheb hetkel nii umbes 2-3L õli. Kaaned on kindlasti korrast sest
neile on kuu aega tagasi kapremont tehtud. Või on kellelgi hoopis korras mootori alumist poolt pakkuda?
juks11
postitati 29.01.06 15:13
Terve 3,6 mootor oleks pakkuda, läbisõit on u 150 000km ja väga korras mootor...
postitati 29.01.06 15:50
Äkki uurid sest 2 tuksis mootoriga pole miskit pihta hakkata.
juks11
postitati 29.01.06 15:55
Algselt postitas: Maqmaq
Asi on võetud täiesti sõitvalt ning korralikult autolt maha, kuna oli vaja varuosi ning varuosadena sai auto eest 3x rohkem, kui tervena müües - auto
oli ideaalses korras
[PHP: 50.8% - SQL: 49.2%]
