Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - K: Bensiini pumba vahetus.
Pealkiri: K: Bensiini pumba vahetus. (Vastuseid: 3 | Vaatamisi: 1055)
Aiku
Registreerunud 03.04.04
Auto: AUDI A6 C5 1,8T 2000a.
postitati 29.01.06 14:47 Tsiteeri
Sai muretserud uus paagi sisene" boschi" bensiini pump , kuna vana teeb juba väga-väga kahtlast häält.
On seda ise väga keeruline vahetada või tuleb lasta seda kuskil töökojas teha.
Iga inf on teretulnud.
villu157
Registreerunud 08.02.03
Auto: VW Passat 2.0 TDI DSG
postitati 29.01.06 15:07 Tsiteeri
Ilmselt siis tegu C3 sigariga
Seal ei ole midagi keerulist. Lähened asjale pagaasnikust. Istme taga põrandal on luuk kolme kruviga. Keerad selle luugi lahti, siis võtad voolikud ja pistiku lahti. Siis lööd haamriga selle stopper rõnga lahti, mis hoiab kogu seda kaader värki koos. Siis tõstad anduri välja ja keerad seest poolt ka voolikud lahti. Sama jutt ka pistikuga. Pistad käe sealt august sisse ja päästad pumba lahti. Istub mingi kolme kummi lutiga paagi põhas kinni. Pead lukustid eemale lükkama ja samal ajal kogu seda möllu seal tõstma. Pärast kõik vastu pidises järjekorras kokku.
Kogu jutt põhineb mälu põhjal ja sellest on palju aega möödas, kui omal sai pumbaga mängitud.
margus0000
Registreerunud 20.02.04
Auto: audi a3
postitati 29.01.06 15:09 Tsiteeri
Lisada veel nii palju et torusid keera ettevaatlikult lahti , lähevad üsna kergesti katki , eriti veel külmaga .
villu157
postitati 29.01.06 15:14 Tsiteeri
Jep, ise sai asjaga suvel tegeletud. Aga kui paned andurit tagasi, siis vähemalt quattrol, ei tea kudas esi veolisel on, jälgi et andur läheb õeti. Vastasel juhul hakkab seier sul poolt paaki näitama. Ise mässasin sellega ikka jupp aega, enne kui sain õieti kokku.
[PHP: 47.9% - SQL: 52.1%]
