Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890 Eesti Audi Klubi foorum - Küsimus käigukasti kohta?
Registreerunud 28.01.06
Auto: Audi 80 1,8
postitati 28.01.06 12:00
Niisiis, küsimus selline. Et kuna äsja läks käigukast õhtale, siis oleks vaja uut. Auto on audi 80 1,8 1986 a. Vana kast on 4 käiguline ja küsimus
ongi, kas oleks võimalik panna sinna 5 käiguline või pole mõtet ja milline see 5ne kast peaks olema?
ettetänades inc
inc
Auto: Audi 80 1,8
postitati 29.01.06 11:38
kas siis tõesti ei oska keegi mind aidata???
Simps
Registreerunud 29.01.05
Auto: erinevad
postitati 29.01.06 12:43
Kas sul on B2 või B3 ? Kui B3, siis peaks saama küll, sest tean päris mitmeid, kes on vahetanud 4-käigulise 5-se vastu.
inc
Auto: Audi 80 1,8
postitati 29.01.06 13:14
B3 on jah
aga on ka mingit tagasisedet sellest vahetusest, et ega mingeid probleeme sellega pole olnud. Ma tean, et mõned ütlevad, et nõrgaks jääb, mitte küll
audi aga üks tuttav Nissanil tegi nii.
Simps
Auto: erinevad
postitati 29.01.06 14:44
Lasid töökojas vahetada...probleeme ei olnud. Ei jää midagi 5-se kastiga lahjaks !
inc
Auto: Audi 80 1,8
postitati 29.01.06 17:56
selge pilt, eks homme remondis selgub aga kui uus siis ikka peaks 5se kasti poole kalduma aga tänud igatahes Simps
[PHP: 48.3% - SQL: 51.7%]
