Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - pöörded ei lähe üles
Pealkiri: pöörded ei lähe üles (Vastuseid: 19 | Vaatamisi: 2726)
Klaabu
Registreerunud 12.07.05
Auto: audi
postitati 20.01.06 17:48 Tsiteeri
nii probleem siis selles et eile sõitsin autoga ja siis järskui pöörded üle 5000 ei läinud siis 4000 ja siis 3000 näna ei läinud enam üle 3000 nii kui teise lõõri järgi võtab teeb häält nagu jääks nälga? käima läheb kohe ja tühi käik on norm.
autoks on 80 2,0 83kw :(
janna
Registreerunud 04.11.05
postitati 20.01.06 20:10 Tsiteeri
analoogne mure.
Mul A-100 2,3E Sama probleem. Arvan, et viga toitesüsteemis aga ei oska kuskilt alustada. Enne kõik normaalne, peale polaaraja tulekut: käivitub ilusti, kuid pöördeid ülesse ei võta. Sõita saab ainult gaasiga meelitades, mingit kiirendust ei ole. Kas peab tõesti ainult kevadet ootama või on veel varjante? TÄNAN.
Klaabu
Auto: audi
postitati 20.01.06 21:11 Tsiteeri
ma ise vahetasin eile kütte filtri ära, puhusin kütte toru läbi, aga ei muhvigi rsk:mad: ei tea mis jama on.
Klaabu
Auto: audi
postitati 22.01.06 16:39 Tsiteeri
oeh kas keegi ei oska mulle miskit nõu anda, nüüd ei kannata enam ültse gaasi vajutada:(
pingvin
Registreerunud 09.10.05
Auto: audi100 89a
postitati 22.01.06 16:52 Tsiteeri
mul sama jama , võtsin ka pensufiltri vahelt , mul on väike plastmassist filter ka vahel , selle jätsin alles. pks tark mees soovitas vaadata tagasivooluklappi, võtsin selle ka vahelt ja panin lihtsalt kolmiku vahele aga nüüd külmadega pole viitsind rohkem jamada nii et ei tea veel kas see on tulemust andnud. mul veel küsimus kas karpal on endal bendsufilter ees ehk on see umbes, karpaks on keichin
Klaabu
Auto: audi
postitati 22.01.06 17:29 Tsiteeri
küsimus selline et mis andur see on
http://www.zone.ee/repsak/untitled.JPG
ette tänades
janna
postitati 22.01.06 18:01 Tsiteeri
Tere! Loen, et murelisi on peale minu veel aga kas keegi oskaks ka nõu anda mida teha? Auto töötab 300--500 p/min. gaasi andmisest pole mingit kasu. Kuidagi meelitades saab pöörded üles aga sõita ju nii ikkagi ei saa. Kas on lootust iseenesest auto tööle saada, kui leian sooja garaazi ja mõned puhurid. Tänud vastajaile.
Klaabu
Auto: audi
postitati 22.01.06 18:04 Tsiteeri
ei tea, minul auto seisab soojas garaazis aga vahet ei miskit
janna
postitati 22.01.06 18:07 Tsiteeri
Siis mul mõistus otsas. (ühes) remonditöökojas vastati mulle, et TALVERÕÕMUD ja kõik.
janna
postitati 22.01.06 20:50 Tsiteeri
ISE KÜSIN, ISE VASTAN. Aga raske uskuda, et enne korras auto ja nüüd ainult vrakk. Palun andke nõu!!!!
jan-kos
Registreerunud 23.04.03
postitati 22.01.06 22:09 Tsiteeri
Sooja kohta,kuskil mingi vesi vast ees,proovida võib mingeid lisandeid veel.
janna
postitati 23.01.06 13:04 Tsiteeri
Lootus kaob.
Lootus pidi viimasena kaduma aga mul on küll mõistus otsas. Auto tiksub, mootor 95-100 C, salong soe aga pöördeid üles ei saa. Puhur juba päev otsa pritsungi juures. Aga sõita oleks vaja!
Klaabu
Auto: audi
postitati 24.01.06 12:24 Tsiteeri
Nonii...käisin kontrollisin bensupumba ka ära, töötab ilusti, rõhk on ok.... Nii et müsteerium jätkub...
Äkki keegi oskab aidata...sest ideed on otsakorral!!!:(
pingvin
Auto: audi100 89a
postitati 24.01.06 17:14 Tsiteeri
mina sain oma veast jagu, autoelektrik andus nõu, oli mingi variaatori kaitse läbi, vahetasin kaitsme ära ja asi ok masin käib nagu kell!
Klaabu
Auto: audi
postitati 24.01.06 18:05 Tsiteeri
Kus see variaatori kaitse asub...täpselt? Vaatasin oma kaitsmed üle...ei saanud aru, et miski oleks läbi olnud. Aga kus see asub täpsemalt?
pingvin
Auto: audi100 89a
postitati 24.01.06 20:00 Tsiteeri
Algselt postitas: Klaabu
minu omal asub kaitsmeploki eesservas on pikuti kaks kaitset, nendest teine kaitse oli läbi. nende kaitsmete peal on veel plastmassist kate mille peal on kiri MOTOR
Klaabu
Auto: audi
postitati 25.01.06 13:05 Tsiteeri
Kaitsmed korras, ka variaatori kaitse! Nii et müsteerium jätkub... Ei tea, mida teha enam!
janar4
Registreerunud 20.11.05
Auto: Audi 80
postitati 25.01.06 14:42 Tsiteeri
minul oli ka külmaga auto väljas, ka ei läinud käima, vahetasin küünlad ära (panin 3 elektrüüdiga) ja hakkas tööle, eelmine kord oli ka sama viga kui pöörded üle 3000 ei läinud
Klaabu
Auto: audi
postitati 25.01.06 17:45 Tsiteeri
Küünlad on vahetatud... ei miskit! Proovisin uue ajuga, kuid oh imet, auto ikka ei käi...:(
oja87
Registreerunud 11.12.05
Auto: A6 13a S-line
postitati 26.01.06 12:55 Tsiteeri
kas autol on kat all, vbl on see umbes
[PHP: 48.2% - SQL: 51.8%]
