Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - K: Mootor jupsib
Pealkiri: K: Mootor jupsib (Vastuseid: 0 | Vaatamisi: 884)
Suun
Registreerunud 24.07.05
Auto: MB E280
postitati 27.12.05 20:46 Tsiteeri
K: Mootor jupsib
Niisiis asi selles et nüüd nende külmade ilmadega tekkinud selline viga et kui vajutada natuke kiirmelat gaasile või üldse nagu kiirust lisada siis pöörded ei tõuse ...
Täpselt nagu ei saaks bensiini või ei ole takt õige...ja siis kui viga hakkab siis sureb lõpuks väja....aga kui saada hoog maateel ülesse ja sõita 5 käiguga 100 juures ühtalset siis e ole mingit viga kui möödaõitu hakata tegema siis sama teema...
Ise arvan et võib olla mingi sodi filtris või tüüsid kinni või siis kõigeparem varjant et lihtsalt vesi kuskile torusse kinni jäätunud...Viisin küll garrazi seisma ex näib kas viga selles...
Kui keegi oskab soovitada siis andke teada....esialgu pusiks ise ei hakka kohe teenindusse tormama...:P
[PHP: 50.4% - SQL: 49.6%]
