Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - K:käigukast
Pealkiri: K:käigukast (Vastuseid: 1 | Vaatamisi: 1017)
kylamats
Registreerunud 06.02.05
postitati 26.12.05 18:36 Tsiteeri
K:käigukast
tegemist siis a100 92a
millest võib selline asi tulla et kui lased autol omal jõul veereda käik sees ilma gaasi andmatta,siis käigukangi nupp liigub natuke edasi tagasi iga käiguga kui sellest hoida.
ja selline asi et kui kui aknad lahti sõita suvel siis on kuulda vahest miski kerge klõks kui gaasi anda peale seda kui auto on omal jõul veerenud ilma gaasi andmatta käik sees.
kui keegi teab selliste asjade kohta midagi seletada siis tänud.
Auto: 6x4x4
postitati 27.12.05 18:37 Tsiteeri
Algselt postitas: kylamats
Vaata mootori ja käigukasti padjad üle, neid ei pruugi seal enam olla :)
[PHP: 49.3% - SQL: 50.7%]
