Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - K: Ratta laagri vahetus.
Pealkiri: K: Ratta laagri vahetus. (Vastuseid: 18 | Vaatamisi: 4210)
Aiku
Registreerunud 03.04.04
Auto: AUDI A6 C5 1,8T 2000a.
postitati 10.12.05 07:45 Tsiteeri
Juba ammu oli plaanis juhi poolne esimene ratta laager vahet. Undas juba koledalt ja töökojas soovitati vahetada. Sai siis eile ka vahetatud ,aga undab nagu varemgi sõidul edasi. Nüüd siis tekib küsimus ,et ehk on hoopis mõne tagumise ratta laager õhtul. Teab keegi kuidas seda kindlaks teha . Samuti tahaks teada ,kas taga on samuti samad laagrid mis ees ja kuis nende vahetamine käib?
Tänud iga infi eest.
audi4ever
Registreerunud 17.05.05
Auto: Audi
postitati 10.12.05 08:04 Tsiteeri
kas sa vahetasid ees mõlemad rattalaagrid ära?äkki lihtsalt teisel pool,niipalju peaks ikka aru saama kas ees või taga!
Aiku
postitati 10.12.05 08:11 Tsiteeri
teise poole vahetasin ees kuu aega tagasi.
Dan
Registreerunud 05.11.03
Auto: VW Golf R Mk7; Audi A3 SB quattro, Audi 80 quattro
postitati 10.12.05 08:20 Tsiteeri
Kui sul on taga trummelpidur siis on vahetamine väga lihtne ja laager on teistsugune aga kui tegemist on ketaspiduriga siis on umbes samasugune laager... Aga see on suht kindel et esimene ja tagumine rattalaager ei ole identsed! Kui kurvis yhele poole keerates hääl ära kaob ja teisele poole keerates hullemaks läheb siis on suht kindel et rattalaager aga kaldun arvama et sul undab midagi muud... Sest tõesti sellest peaks ikka aru saama kas esimene või tagumine ja kui sul esimesed mõlemad vahetatud siis... Suht pikk jutt aga loodan et said targemaks;)
QUATTRO
Auto: 5,2 Cherokee 4x4
postitati 10.12.05 08:22 Tsiteeri
Esiveolisel on taga ketta ja trumli puhul põhimõtteliselt sama laager.Ärge tekitage siin paanikat.
Ketaspidurri puhul on vahetus löihtsalt vähe aeganõudvam,ning vaja läheb head 8 mm sisekuuskant võtit.
Aiku
postitati 10.12.05 08:32 Tsiteeri
mul on taga loomulikut ketas pidurid. Tunnen huvi ,et kas tuleb ka ,nagu ees püstik maha võtta või saab lihtsamalt.
QUATTRO
postitati 10.12.05 08:42 Tsiteeri
Ratas alt ära,pidurisadul maha ja siis kahe 8mm kuuskandiga maha sadularaam.Rattarummu plekist tolmukate maha,splint välja,24 mutrivõtmega mutter maha ja ongi käes.Nüüd torniga vanad laagrid välja ja sobilike junnidega uued sisse.Määret peab varuma ainult,kuna poekomplektides ei ole seda alati kaasas.
Aiku
postitati 10.12.05 09:10 Tsiteeri
Tänud asjaliku infi eest. Kui tekib vajadus siis vahetangi ära. Aitähh.
Aiku
postitati 10.12.05 14:26 Tsiteeri
Sai siis täna juba neid tagumisi laagreid uuritud. Seal hoopis koonus laagrid ja neid on tõesti lihtne vahetada. Ainult ,ei tea kas on põhjust neid vahetada. Ei tundu nad sugugi seda moodi ,et oleksid kuuma saanud. Ehk aitab uue määrde panemised ja mutri uuesti pingutamisest.
andro
Registreerunud 19.03.05
Auto: audi 80 avant B4
postitati 10.12.05 19:15 Tsiteeri
Algselt postitas: Aiku
Kui undavad siis undavad, määre ei aita. Abiks aind vahetus.
A.
irbusk
Registreerunud 25.11.04
Auto: Audi 80 1,8 91.a.
postitati 14.03.06 11:51 Tsiteeri
MInu Audil tekkis hiljuti selline jama siis. Vasaku esimese ratta juurest tuleb vigisevat või sellist kriipivat heli. Sõidust tulles on ketas ka tuline. KAs see võib olla tingitud piduriklotsi peale jäämisest või on rattalaager nii peetis, et vigisema hakkab. Mingit undamist küll täheldanud varem pole. Kas ka nii on võimalik, et lihtsalt ilma undamiseta laager peeti läheb?
Ja kui ongi laager peetis, siis kuidas onkõige parem ABS-i andurit kätte saada, sest kavas on ikka ise vahetada.
postitati 14.03.06 14:18 Tsiteeri
Algselt postitas: irbusk
Kahtlustaks rohkem seda. Tõsta ratas üles ja proovi käsitsi ringi ajada.
priit121
Registreerunud 25.07.03
Auto: B4&CR-V
postitati 15.03.06 19:20 Tsiteeri
sama jama oli,peale klotside vahetust kõik ok,kuigi kulumisruumi nagu oli...
Millele tiivustab, või kuidas meid kasvatab naisolend, kes jääb, andke andeks, tagumikuga lakaluugi vahele?
genekas
Registreerunud 30.01.03
Auto: järgmist plaanimas
postitati 16.03.06 22:56 Tsiteeri
kriipiv heli? Kivike vms jäänud sadula serva taha kinni???
irbusk
postitati 18.03.06 07:09 Tsiteeri
JA oligi piduriklots peal, kusjuures välimine. Võtsin siis ratta alt ja logistasin teist veits, hakkas jälle tööle. Täna hommikul tööle sõites jälle kinni, ketas kuum kui kurat. Nüüd nõu vaja, mida oleks seal vaja puhastada? SAdul liigub ilusti, kinni pole jäänud.
Aiku
postitati 18.03.06 07:20 Tsiteeri
Kas ka klotsid sadula soontes vabalt liiguvad? Kui jah, siis ikkagi pidurikolb silindris kinni .
irbusk
postitati 18.03.06 07:29 Tsiteeri
Pidurikolb ei ole kinni, klots lihtsalt oma pessa kinni jääb. KUda toda pesa kõige otstarbekam puhastada on, traatharjaga ja miskit möksi sinna vahele?
priit121
Auto: B4&CR-V
postitati 18.03.06 17:48 Tsiteeri
traathari ja vaskmääre minul abiks olid ,siiani pole mingit muret
irbusk
postitati 18.03.06 18:32 Tsiteeri
Algselt postitas: priit121
Tänud priit, puhastan teda siis harjaga ja libestit ka sinna vahele veits :D. Tänud ka teistele, kes viitsisid kaasa mõelda.
[PHP: 50.3% - SQL: 49.7%]
