Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - A4 td 81kw 99a automaat jukerdab.
Pealkiri: A4 td 81kw 99a automaat jukerdab. (Vastuseid: 1 | Vaatamisi: 896)
marten28
Registreerunud 03.06.04
postitati 19.11.05 20:44 Tsiteeri
selline kummaline asi et kui kast lukustab ühtlasel sõidul hüdrotrahvo N: 85km/h siis hakkab auto sedasi kummaliselt mingi hetk värisema nagu olex tee rataste all treppis.siis läheb jälle ära ja samas tuleb jälle tagasi.intensiivsemalt aga siis kui vedu suurendad.
Kas kellegil on sellise asjaga kokku puudet olnud ja kas on bensukatel samasi vigasi esinenud. et kas on viga nüüd hüdromuhvis endas või selle juhtimises.ja palju selline asi maxta võix?
marten28
postitati 20.11.05 17:24 Tsiteeri
et kas hakkab hüdrotrahvo mingilmääral läbi libisema või mis saab ültse seal sees tuksi minna.kas neid kusagil ka remonditakse. kas on viga h.trahvos endas või on tulemus selles,kas võib olla viga ültse hüdraulika juhtplokis.õli ja filter on korras????????? kastispetsid uuuuu antge nüüd tuld :-) :-) :-)
[PHP: 52.7% - SQL: 47.3%]
