Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - Mitu hammast on....
Pealkiri: Mitu hammast on.... (Vastuseid: 13 | Vaatamisi: 1579)
kaimagk
Registreerunud 09.08.05
Auto: 1,4 tsi vag
postitati 09.11.05 18:12 Tsiteeri
Mitu hammast on....
......siis hammasrihmal(v6 2,6)?
Mul on rihm olemas ,aga ei tea kas on ikka õige.Karp on teine.
Ise pole ostnud seda,sellepärast küsingi.
aitäh.
lukas
Registreerunud 29.07.04
Auto: paar käru
postitati 10.11.05 06:36 Tsiteeri
Keegi ei hakka mingil 2 meetri pikkusel rihmal ju hambaid lugema.
Kuigi uudishimust tahaks teada küll mitusada hammast seal olla võiks :D
Vahet ei tehta hammasrihmadel mitte hammaste arvu vaid ikka mootori tüübi järgi.
rass
Registreerunud 25.09.02
postitati 10.11.05 06:40 Tsiteeri
239 vist? Loe üle endal, kui on 239 siis on hästi :)
ETKA kataloog lihtsalt ütles hammasrihma juures Z=239, eeldan et äkki see on hammaste arv.
ferdinand
Registreerunud 17.01.03
Auto: 400,401,969
postitati 10.11.05 08:17 Tsiteeri
Algselt postitas: lukas
A mille järgi siis neid rihmasid eristatakse sinu arvates? Ikka hammaste arvu järgi käib nende identifitseerimine.
lukas
Auto: paar käru
postitati 10.11.05 08:36 Tsiteeri
Tahad öelda et 2,6 sel V6 on mitut tüüpi hammasrihmasid. Kahtlen selles sügavalt. Või et mõne ridamootori ja v6 rihm sarnane ja lihtsalt hammast arv on erinev???
Väga vabandan, aga ma ju ei küsi poest et müüge mulle palun hammasrihm millel on 239 hammast ja siis poes müüa läheb otsib mulle sellise? Küsin ju ikka aastaarvu ja mootoritüübi järgi :o
Kui tõesti hammasrihmade identifitseerimine hammaste arvu järgi käib siis vabandan oma ebakompententsuse pärast.
ferdinand
Auto: 400,401,969
postitati 10.11.05 08:39 Tsiteeri
Tahad öelda et 2,6 sel V6 on mitut tüüpi hammasrihmasid. Kahtlen selles sügavalt. Või et mõne ridamootoriga v6 rihm sarnane ja lihtsalt hammast arv on erinev???
Kui tõesti hammasrihamde identifitseerimine hammaste arvu järgi käib siis vabandan oma ebakompententsuse pärast.
Ei tea kuidas V6'ga on, kuid r5'ele forsist rihma ostes oli küll hammaste arv määravaks ja suht väikese hammaste arvu erinevusega rihmasid kasutusel mitmeid.
lukas
Auto: paar käru
postitati 10.11.05 08:43 Tsiteeri
ok jutt väga OT-ks läinud aga ju siis r5 on tõesti aga jah elcats näitab v6 nii 2,6 kui ka 2,8 pakub ainult ühte koodi. Ja Z=239.
LINK
Lihtsalt mulle tundus algul see küsimus a´la stiilis mitu jalga on sajajalgsel? :D
audi-äss
Auto: 4WD ARBUUS
postitati 10.11.05 09:28 Tsiteeri
muide, ostsin mina rihma ja 2 pingutit poest.(komplekt) ja ülla ülla oli audi80 v6, 2,6 ja ei sobinud:( tuli välja, et neid on erinevaid. ja siis kataloogi vaadates, oli kere nr'i järgi tõesti erinevad. olen näinud 2 erinevat komplekti:)
lukas
Auto: paar käru
postitati 10.11.05 10:46 Tsiteeri
hmm, imelik jah. Aga mis seal siis teistmoodi oli. Vaatan siin nii a6 kui a80 järgi etkast ka ja ikka kõigil 1 kood.
samas nüüd endal ka hea teada et järgmisel korral vin kood rihma soetamisel abiks.
V200
Registreerunud 11.09.04
postitati 10.11.05 11:13 Tsiteeri
Siin lehel on juttu ja pilte rihma paigutusest:
http://www.12v.org/engine/index.php?section=cl&view=sbelt
Need pildid on vist 2,8 L mootori kohta, aga äkki on 2,6 L mootoritel ka mingi selline erinevus?
lukas
Auto: paar käru
postitati 10.11.05 11:31 Tsiteeri
see ju soonrihm, arutelu ikka hammasrihmast
V200
postitati 10.11.05 11:43 Tsiteeri
Ehh, minu viga, ei vaadanud korralikult... ;)
postitati 10.11.05 12:06 Tsiteeri
Hambaid on jah 239 tükki , nii näitab igatahes www.autoosad.ee .Pingutusrullikuid ja juhtrulle on küll erineva mõõduga selle järgi. (A6;2,6)
Seal numbrid kirjas mille järgi vaadata.
kaimagk
Auto: 1,4 tsi vag
postitati 10.11.05 18:29 Tsiteeri
Sain siis vastuse.
Loen üle ja vaatan koodi ka.
Aitähh.
Teema võib sulgeda.
[PHP: 48.0% - SQL: 52.0%]
