Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php on line 48
Deprecated: Optional parameter $dbhost declared before required parameter $dbname is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/database.interface.php on line 33
Deprecated: Optional parameter $type declared before required parameter $name is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 93
Deprecated: Optional parameter $pass declared before required parameter $fid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1056
Deprecated: Optional parameter $user declared before required parameter $tid is implicitly treated as a required parameter in /data01/virt4271/domeenid/www.audiclub.ee/foorum/functions.php on line 1550
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 146
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 147
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 148
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 155
Warning: Cannot modify header information - headers already sent by (output started at /data01/virt4271/domeenid/www.audiclub.ee/foorum/db/mysql4.php:48) in /data01/virt4271/domeenid/www.audiclub.ee/foorum/header.php on line 890
Eesti Audi Klubi foorum - mootori kap remont!!!
Pealkiri: mootori kap remont!!! (Vastuseid: 5 | Vaatamisi: 1278)
kalver6
Registreerunud 13.06.05
Auto: audi 100 2,6 avant
postitati 04.11.05 19:50 Tsiteeri
mure siis selline, et tuleb ette võtta mootori remont. palju võiks minna kui teha seda täielikult, et vahetada kõik mis vahetada annab....mootor siis V6 audi 100-l
juks11
postitati 04.11.05 19:55 Tsiteeri
Algselt postitas: kalver6
Vastust sellele küsimusele ei ole...!!!
kalver6
postitati 04.11.05 19:57 Tsiteeri
Algselt postitas: juks11
ju siis tuleb panka röövima minna ja loota et saab piisavalt suur kott kaasa võetud
juks11
postitati 04.11.05 20:07 Tsiteeri
jep!
juks11
postitati 04.11.05 20:08 Tsiteeri
Kõik ju sõltub sellest, kus teed, mis osasid kasutad, kui suures ulakus remonti teed, mis on läbi jne...
rax21
Registreerunud 06.01.04
Auto: 2,5 4wd
postitati 05.11.05 06:49 Tsiteeri
no arvesta ca 15 k siis kui vahetad nii öelda hädavajalik.
Ja kui põhjalik remont kas ka raamsaaled ja erinevad otsa simmerid siis tuleb juba sellele summale juurde liita. Ja kõigele juurde veel ka tööraha juhul kui sa ise ei tee
[PHP: 48.2% - SQL: 51.8%]
